I'm after some recommendations for a color laser printer. The problem is most are just so expensive, does anyone know of any good quality but affordable laser printers?
I've had it with inkjets I've tried the main brands and most just start turning out crappy, smudged pictures with all sorts of problems after a while no matter how much cleaning you do.
So any personal experiences would be helpful and also any links to any sites people might know of that maybe specializes in printers with reviews etc would be helpful.
My budget is I guess around the 700-800ish mark, i know that narrows the playing field considerably but there must be some decent ones out there.
Thanks.
Thanks.
