dust
I'm fairly new at all this so forgive me if I'm saying stupid things, but I see no reason to go for an I7 yet. I always had the impression that the first gen of anything is not properly tweaked from factory, same as the software if you wish. Like many already said, the I7 runs very very hot right now, I've seen posts here where the idle temps were little above 60c and well above 75-80c under load and that was with mild overclock only.
If you check the PC Gaming section you'll likely find some benchies for FC2 where it's clearly shown the performance gain ?!? of an I7 920 over a qx9770 and a c2d all of them at stock speeds( 3,2 for the first two and only 3,16 for the c2d). At low resolutions the I7 and the extreme outperform the c2d but at high resolutions the difference is not that obvious as the game becomes more gpu tied. Also the extreme clearly outperforms the I7 in this particular app. Consider also that the I7 came with 6gb DDR3, the quad with 4gb DDR3 and the duo with 2gb only.
I myself have an yorkfield and my next cpu will be an qx9770 not an I7 even towards the mid of next year, when the price would be low enough. For the next gen I'll start thinking maybe after another year as I'm sure there will be better options to choose from. Right now, as I can see, the only gain is having more windows open at the same time with an I7 but that's about it.
I think someone said it best here earlier, sell the I7 and build a yorkfield platform, it should be ok for you for a couple of years from now and consider the fact that whatever is latest today will be obsolete in a few months, therefore lesser priced.
