What would be nice upgrade to ATi 9800 pro
Originally posted by: Captante
Originally posted by: Mir96TA
Shall I look used X850XT?
What brand should I look into?
Keep an eye on FS/FT for a used 6800GT/Ultra or an X800XL/X850XT ... one of these 4 will offer the best performance in a used card, especially the XT which will keep pace with a 7800GS in most benchmarks & outperform it in some too.
New cards will cost quite a bit more in AGP format & the best bet for the money will be the 7600GT AGP.
Good
Please posted in order of performance with avg price next to it (Used)
Originally posted by: munky
For that price, your only choices are a 7600gs or a x1650pro. Both of those are only slightly faster than a 9800pro.
A month ago I upgraded to a 512mb x1650 pro from my dead 9800 pro and its not good enough. Games play a little better but not what I was expecting. I'm going to sell this and get a x1950 soon.
Good
Listed in rough order of performance in most games from fastest to slowest ... prices are rough estimates because I havn't been keeping up on FS/FT prices lately:
(1) X850XT / XT-PE - fastest of the bunch by a good margin, especially if you can find a "PE" (Platinum Edition) ... X800XT is harder to find but very close in performance ($100 - $140)
(2) 6800 Ultra - Really its a tough call between this & the X800XL performance-wise ... needs a bit more power the 6800GT & some models have a loud fan ($85 - $125)
(3) X800XL - Runs quieter & cooler the the X850XT but considerably slower too - As mentioned very close in performance to 6800 Ultra ($70 - $100)
(4) 6800GT - Lower clocked version of the 6800 Ultra with smaller HS/fan & lower power draw - many can be overclocked to Ultra default levels, but will run very hot ($65 - $100)
You could also consider an X800 Pro which you may be able to find for +/- $50 but performance is only a bit faster then a 9800 Pro in many cases.
The x800pro (12pp @ 475mhz) is a bit slower than the 6800gt, but it's still a good deal faster than a 9800pro.
Those are I am going go after
I do not want which draw lot of Heat or Noise.
I think those should work ok with Artic Cool HSF
right
if you can find cheap X850 Pro with VIVO and you can modify BIOS it into XT/PE. ATI brand name is the best in the class
How Sapphire Radeon X850XT 256MB AGP Recertified for $ 110 ?
That sounds like a pretty good deal, depending on what "recertified" means ... where did you see one for that price?
Edit: I'd go for the XT ... theres no garantee the X850 Pro will flash to an XT without problems & the XT is a lot faster.
For the price you really can't beat the X850XT for $110 because it will beat a 7600GT in virtually every benchmark/game & will be very close to or match the 7800GS at those resolutions, plus will save you $50 or more.
The X1950GT would be faster than any of the cards we've discussed so far, so I think it should really come down to a choice between it & the X850XT... the cards in between arn't worth their additional cost over the XT & can't match the GT's performance.
110 is really dirty cheap I think you can buy it now.
How to: Flash your X850Pro To XT/PE and unlock 16 Pipes!
or
How to: Mod your x800/x850
I endup getting X850 Pro for $105
I unlock to 16 Pipe lines
When I compare in 3D Mark 03 I notice it alsmost DBL the speed of 9800 Pro
Thank Guys
All suggestion were good
Thank
Mir96TA :thumbsup:
