What were the specs of the first computer you ever built yourself?
Raswan
702
Athlon Xp 1600+
GeForce gts something or other
2X512mb Corsair
40gb Maxtor IDE
Lite-on 32x Cd rom
300W something
All purchased from mgepc.com (upon recommendation of some friends), who, upon assembly and after the psu immediately burst into flame, pretended I never existed and promptly went out of business. Some friends. Purchased a new one from newegg, customer ever since. I worked 40hrs a week for a month to save the $600 to buy that pos. Gotta love it, though.
F1N3ST
3,802
E6300 "Conroe" 1.86Ghz
2x1GB DDR2-667 4-4-4-12 PQI Turbo
ECS P965T-A
80GB HD
eVGA 7600GT
XION-XON 103 Case + 450W PSU
Weird how I remembered all of that.
yh125d
6,886
Sempron 3000 (939)
512mb DDR
Some cheapy MSI board
EVGA 7600GT
misc old as hell parts for everything else
loafbred
836
58
Some Enlight case with bundled psu.
AMD K6-2 350.
RAM (?).
nvidia TNT-1 video card.
A Diamond Voodoo2 12mb video card.
Whichever Sound Blaster was current.
An Epox board with VIA chipset, which worked decently.
A US Robotics 33.6K modem.
A Toshiba CD-ROM.
I cut a square hole in the side of the case and added an 80mm fan. I also drilled all of the tiny holes in the front plastic panel to ~1/4" diameter.
The Celeron 300a's quicly made it obsolete, so I soon changed to one of those with an Abit BM6 board. I've had upgrade fever ever since.
F1shF4t
1,583
Had a P4 2.8 and 3.2ghz comps which over time I would have rebuilt from scratch. But the first comp I've build from scratch would have to be:
Athlon 64 3200+
Asus A8V Deluxe
2gig of noname brand ram (Or was it 1gig, back then it was enought :p)
6800 ultra
Superflower 500watt psu
The 6800 Ultra died so i picked up a DFI Ultra-D to use with the replacement pcie 7800gt :D. The asus board I sold to my boss at work. I later changed the cpu to a X2 3800+ and had it clocked at 2.7gh. Had that comp for a while till could afford a q6600.
fffblackmage
2,548
The first comp I built didn't last long... it ended up going to my aunt (and she still has it!).
Athlon XP 2000+
MSI mobo with some sort of VIA chipset
2x256MB Kingston DDR-266 ram
GeForce 2 MX
Recently replaced the dying WD 80GB HDD with a spare WD 160GB.
Case+psu was some random cheap thing I picked up at Fry's, free after rebate, during a Black Friday sale. Don't you just miss those old days when free after rebate was common?
So the computer I built and actually kept for myself until my current rig:
Athlon XP Barton core 2600+
Shuttle nForce 2 (no dual channel memory, not like it really mattered much at the time)
3x256MB DDR-333
GeForce 4 MX440, upgraded to 6600gt for a short while
Enermax case + 350Wpsu (also got it from Fry's during another Black Friday sale)
After I got my new rig going (for weekend gaming), I was still using my Athlon XP comp as primary (dorm use). I didn't care about frying the old comp, so I went off on a crazy OCing adventure. Ramped up voltage to the max the mobo could do - 2.0V. Bumped up the FSB from 333MHz to 400MHz. That increased cpu freq from 1.9GHz to 2.3GHz. It cannot run Prime95 for 2 seconds without errors. But that still ran fine for a month before getting my first crash. Temps were up to an insane 60C? or was it 70C under load? It was a very nice space heater... that's for sure.
The interesting part is killing the comp on the underclocking adventure afterwards....
Comp refuses to boot to WinXP (even after reformatting), but installs/boots into Ubuntu fine.
Gustavus
I was a radar maintenance tech on Guam in 1950 -- just before the Korean war started -- and my CO was a Harvard graduate who received the Alumni news letter. In one of them was a paragraph or two about a machine that had been built -- or perhaps only designed at that point -- by two undergraduates, Kalin and Burkhart, which could evaluate the truth table for logical expressions. The example mentioned was checking the terms of an insurance policy for logical consistency. He showed it to me and asked if I knew what they were talking about. I didn't, but asked him to let me take it back to the barracks that evening. By morning I had designed relay circuits that could realize and, or, if then, if and only if, negation, exclusive or etc. The most it required were two DPDT relays for the most complex functions and a single SPDT for negation. He asked if I could build such a machine and I said yes -- given enough relays. Aircraft used 28v relays so he got on the teletype and requisitioned from every supply site from Honolulu to Tokyo their stock of 28v DPDT relays. They must have thought that every aircraft at Anderson AFB had been struck by lightening to kill so many relays. Using two ganged telephone rotary stepping switches I wired up a 10 variable input -- i.e. it had ten output wires that would sequentially step through the 1024 states for 10 logical variables. Using the 28v aircraft relays I constructed modules for a large number of the functions that could be wired using pin jacks and pins from the front of the console. You set in the logical expression whose truth table you desired to map, turned on the stepping unit at state 0 --- 0 and let it step it's way through the 1024 states. When a state was reached for which the logical expression was true, a current flowed through the circuit closing a relay and stopped the stepping switches. You could then copy down the values for the ten logical variables from the state of ten lamps on the front. Pushing a button then caused the stepping switches to resume. At the end, you had the truth table for the original logical expression. It was the most satisfying computer I have ever built -- with all those relays clicking in and out and lights flashing as states changed. We named him George -- and when I returned from the South Pacific in 1953 managed to ship him home as hold baggage and talk my way through the port inspection. The secret was that George didn't look like anything they had ever seen and they were mostly looking for people trying to steal government property. He entertained a whole generation of student engineers just as digital computers were coming on the scene.
MagickMan
7,460
PC-XT 8086 4.77MHz (8MHz turbo, later OCed to 10MHz) w/ 8087
640KB RAM
10MB Miniscribe MFM HD (full height 5.25") on an RLL controller for 18MB
3.5" 720KB and 5.25" 360KB FDDs
Hercules CGA video (yeah, the card that was >$400)
13" Magnavox CGA monitor
iluvdeal
1,975
It's been awhile and I don't remember all the parts but here's what I do remember, I got these parts at a computer show (lol anyone remember those?):
Celeron 300A (overclocked to 450Mhz of course)
Abit BH6
Creative Labs Riva TNT
That computer actually lasted me a really long time. The Celeron 300A was a Pentium II generation CPU, I was able to upgrade to a Pentium III gen CPU, a Tualatin 1.2GHz, by using a slotket adapter. Pretty cool a change in the cpu socket type didn't automatically mean you had to get a new mobo to upgrade back then.
StrangerGuy
8,443
124
K6-2 500MHz (Way too slow for 2002 but enough to play CS)
GA-5AA 512KB L2 (onboard L2 cache FTL)
128 MB PC133 SDRAM
Geforce 2 Ti 64 MB (Way overpowered for the CPU)
30GB Maxtor 7200rpm HDD
SB Live
Windows 98
Then I upgraded to a Celeron 433 which was way faster than the K6-2 (still good for Warcraft 3), then finally to a Athlon XP 1700+...That was like from walking to flying.
DrMrLordX
23,226
13,304
First PC I ever specced out was a 386dx40 with 4 megs of RAM. Didn't build it myself though.
First PC I ever built myself from scratch was a 1.4 ghz Tbird on an ECS K7s5a with . . . I don't remember how much RAM. It started life with a GeForce 2 Ti 200 and wound up with a GeForce 4 Ti 4200 before being decommissioned and then later donated to someone who needed a computer. The box went when the cheap-ass replacement PSU I put into it prior to donation died (originally it had an Antec Smartpower, I think 380W, that currently powers my old Sempron). Current status on the machine is unknown since my offers to repair the problem went largely ignored.
Rhoxed
1,051
2 at once for me
#1
Athlon XP 2500+ @ 2.3
ABIT AX??
1GB DDR 400
GF FX-5700
250GB IDE
420W TT PSU
#2
P4 2.4 @ 3.2
Asus P4P800-SE
2GB GEIL DDR 400
GF FX-5800XT
250GB SATA
420W TT
Mir96TA
1,952
39
386 DX20 256 Meg Ram 6 of them ! in 8 hrs
Monochrome Card with LPT Card built in to it
aigomorla
21,131
3,666
mmm the first computer i assembled...
It would probably be a 486DX33 i dont remember how much ram tho... i know i ended it at 256megs tho...
I had a OG sound blaster.
The videocard i think was a trident...
EnzoLT
1,843
4
Athlon 64 3000+ S754
MSI 6702?
Value Select Ram
9700 pro
random case and random psu
lasted for a good 4-5 years then the psu melted the atx 4pin
bigboxes
45,150
12,456
AMD Athlon Thunderbird 1200
Abit KT7A-RAID (Socket A)
2x 256MB Kingston PC133 SDRAM
ATI Radeon 64 VIVO
Soundblaster knockoff soundcard
Maxtor 10gb 5400 RPM
Cooler Master ATC-200
Antec 300W PSU
Intel keyboard
Mitsubishi Diamondtron 91U 20" Aperture Grill CRT
Windows 98SE
Apr 20, 2008
10,067
990
I was a radar maintenance tech on Guam in 1950 -- just before the Korean war started -- and my CO was a Harvard graduate who received the Alumni news letter. In one of them was a paragraph or two about a machine that had been built -- or perhaps only designed at that point -- by two undergraduates, Kalin and Burkhart, which could evaluate the truth table for logical expressions. The example mentioned was checking the terms of an insurance policy for logical consistency. He showed it to me and asked if I knew what they were talking about. I didn't, but asked him to let me take it back to the barracks that evening. By morning I had designed relay circuits that could realize and, or, if then, if and only if, negation, exclusive or etc. The most it required were two DPDT relays for the most complex functions and a single SPDT for negation. He asked if I could build such a machine and I said yes -- given enough relays. Aircraft used 28v relays so he got on the teletype and requisitioned from every supply site from Honolulu to Tokyo their stock of 28v DPDT relays. They must have thought that every aircraft at Anderson AFB had been struck by lightening to kill so many relays. Using two ganged telephone rotary stepping switches I wired up a 10 variable input -- i.e. it had ten output wires that would sequentially step through the 1024 states for 10 logical variables. Using the 28v aircraft relays I constructed modules for a large number of the functions that could be wired using pin jacks and pins from the front of the console. You set in the logical expression whose truth table you desired to map, turned on the stepping unit at state 0 --- 0 and let it step it's way through the 1024 states. When a state was reached for which the logical expression was true, a current flowed through the circuit closing a relay and stopped the stepping switches. You could then copy down the values for the ten logical variables from the state of ten lamps on the front. Pushing a button then caused the stepping switches to resume. At the end, you had the truth table for the original logical expression. It was the most satisfying computer I have ever built -- with all those relays clicking in and out and lights flashing as states changed. We named him George -- and when I returned from the South Pacific in 1953 managed to ship him home as hold baggage and talk my way through the port inspection. The secret was that George didn't look like anything they had ever seen and they were mostly looking for people trying to steal governenment property. He entertained a whole generation of student engineers just as digital computers were coming on the scene.
Paragraphing fail :awe:
biostud
20,193
7,311
Pentium-75
8mb ram
diamond stealth 64 2mb videocard
15" monitor
some fancy add in harddrive controller that boosted the speed of my harddrive
can't remember the rest
ahenkel
5,357
not sure of the specs but first one I built on my own was a 486. Dad bought the parts and a book and said learn it. You screw it up you pay for it.
Later on my first I did the research and paid for it build was a K6-2 build again fuzzy on the specs.
MegaWorks
3,819
Intel Celeron 1.0 GHz (Tualatin-256) @1.4Ghz :biggrin:
Abit ST6-RAID 815EP
512MB PC-133
2xWD 40GB in Raid 0
Asus Geforce 2 GTS 32MB then switched ATI Radeon 9500 Pro ():)
Sound Blaster Live! value
Antec 480W TrueBlue
Played a lot of Counter-Strike with this rig! ^_^
krose
514
15
Epox 8K7A
AMD Athlon Thunderbird 1.33 GHz
GeForce TNT
2x128 MB DDR 266
40 GB WD HDD
Turtle Beach sound card from my old Dell
Generic case w/ 300W PSU
Meghan54
11,684
5,228
First computer I ever assembled was an 8088-based thing....put it together from parts scavenged from several dying or dead computers.
First computer I built from parts I purchased was a 386DX40 based computer. The cpu and mb were purchased from Aberdeen and they neglected to mention the cpu was soldered to the mb, not socketed.
