what tool to use to cut fine pictures in case side
Tyson82
491
ANyone do this yet? I need to know what tool to use. I think a sabre saw is too big, and I cant find a decent metal cutting dremel attachment that isnt a wheel.
Any suggestions?
BG4533
1,892
How fine and how big? Would a dremmel with a drill bit work? If not, someone else in a different post mentioned a tool that pokes thousands of little holes to make a cut out. It was from Harbor freight. I dont remember the name of it and I dont have time to look for it.
Brian
chizow
9,537
Brian
You're thinking of an air nibbler. There are also hand nibblers out there. Very precise and controllable cuts at the expense of time/effort.
Chiz
chizow
9,537
Originally posted by: Tyson82
gimme a link for the nibbler would ya.
In this thread.
I linked it in one of my posts. The air nibblers are a bit more effort though and pricier. I didn't pursue it. The hand nibbler works great though, carves through aluminum and plastic like a knife through warm butter :)
Chiz
Wintermute76
364
I"ve used small endmills in my dremel before with pretty good luck. Most mills under 1/8" still have 1/8"shanks. and they come in a variety of sizes all the way down to .005". Most industrial supply places should stock them.
JaRb0y
168
how would a nibbler be able to do that design? if u want to cut something in the middle of the case cover for example. is it possible? id like to try something like that and id rather deal with a hand tool then a dremel.
chizow
9,537
You just need to drill a 3/8'' hole or use a hole-punch for a pilot hole. Then nibble away :)
Chiz
skerd
43
the nibbler isnt excatly easy to use...your hands will hate ya for it..but it works
Tyson82
491
the other problem I forsee with the nibbler, is that it cant do small cuts. there has to be at least a 3/8 hole to fit it down in to do the nibbling.
Im going to try out a sabre saw on some practice metal, see if I can keep the cut clean. And also some heavier duty dremel discs.
BTW Wintermute76, what do you mean by an endmill?
