What tool do I use to open this lock?
Sketcher
2,237
Originally posted by: csaddict
Originally posted by: Sketcher
3 Flat head screw drivers.
Vertically wedge two of the screw drivers on opposing sides of the "circular" groove. While applying pressure on the two wedged drivers, use the third screw driver as a pry bar by inserting it horizontally between the two vertical screw drivers and applying leverage in a clockwise or counter-clockwise rotation.
Dude, a vise-grips would be sooo much easier.
Dude, the above steps are quite simple. If you look at that picture closely you'll see the outer edge of the lock is tapered and the height of the lock is rather shallow. A Vice Grip 'could' work but it's not likely. One of the reason for designing a surface in this fashion is to defeat most common tool leverage.
*Note that this isn't necessarily a "Lock" in the mechanical sense. There is no mechanism other than the requirement of a unique application to provide leverage for operation.
**Our locksmith actually has a tool for this. He said just use one of those universal pin type sockets that you see on cable shopping networks. Just make sure the pins are small enough to fit in the grooves and enough of the pins will insert that it can be turned with a socket wrench. He has a few different sizes of those sockets and he said if those do not work, he either orders the correct key, molds a key to fit (at considerable expense) or just drills it out and uses a torx bit.(at the owners insistence).
IamElectro
1,470
It looks like one of those security wheel locks to me. If its the size of a lug nut check auto parts stors for someting to fit it.
rudeguy
47,351
14
61
what did you steal?
that looks like a security device...and the only way to get the key to it is to either be the owner, or call the company that made it and have them send you the key...care to inform us on the details of this?
compslckr
327
alright, here is what you need to do. go to ocean state joblot or the "as seen on TV" store at a mall or something and buy a "gator grip" you could prob get it on ebay too. then just stick the gator grip on a normal ratchet and open it right up. i still want to know what that is a "lock " to
Nocturnal
18,927
It looks like there is a key for that specific lock. So it's highly doubtful you'll be able to find a screwdriver that will take that off. I would try drilling that thing out if you can't find the original key.
