dud
I know this question has been asked many times before but am hoping to get up-to-date info and advice when it comes to buying a new monitor in the next 2 months. I am currently using an old Samsung 930B Synchmaster LCD that I bought 5 years ago ... for $300! I am ready for a change and want more real estate. I use my monitor for light gaming, general surfing and some word processing and CAD work. I've come across the following snipets of information that may/may not be accurate (please advise):
- Larger can be better but pixel pitch increases as screen size does so the picture quality of a 27" monitor may be inferior to that of a 24" monitor. The screen will be larger but assuming the same resoulution (say 1900x1200) the pixels on the 27 will be larger.
- IPS monitors can be considered to be suprior to TN panels in color reproduction and off-axis viewing but may not be as good in gaming.
- TN panels are typically far less expensive than IPS panels of the same general size.
- The general concensus (that I've seen) is that 1900x1200 is a superior and much more preferred screen resolution than 1900x1080 ... even though most larger monitors are 1900x1080.
My first instinct was to go TN and as big as possible over my current 19" display. Asus, Samsung and others make 1900x1200 and 1900x1080 monitors in the 25 to 27" range. I noticed that the pixel pitch increased from about 0.275 to 0.32 as the aperture of the screen I was considering increased. I now am focusing more on something in the 24" range as a happy medium ... significantly larger than my 19" but with a pixel pitch that would provide good clarity. My research has lead me to the following:
Screen size 23-25"
Screen typ: TN
Resolution: 1900x1200 if available
Manufacturer: Unknown
I am also consider what I call a "wildcard" display. Dell has a 27" Planar for $249 with free shipping. Yes, it's big and the pixel pitch is big at 0.3114 and yes, it is 1900x1080 but did I mention that it's big? Three things are holding me back ... it's not from a well known manufacturer, has few reviews and it's 1900x1080.
I will probably go with something in the 24" range with a 1900x1200 resolution if possible. My question is ... am I using correct logic and heading down the right road and what monitor would you recommend?
I'm looking for any all advice that I can get and am hoping that (as the holidays approach and others consider a new monitor) that the advice provided here can be helpful to many.
Please buzz in and be heard. Thanks and I really appreciate it. Thanks ...
Moved from PC Gaming
Anandtech PC Gaming Moderator
KeithTalent
Screen size 23-25"
Screen typ: TN
KeithTalent
