Midwayman
- Jan 28, 2000
- 5,723
- 325
- 126
5 gallon bucket swamp cooler
Yup. Swamp cooler is the answer (Though an ice chest with ice in it is more effective than a bucket.)
Does this actually work?
No.
It may make you feel better if you stand in front of it.
Overall it will make the room warmer.
Buy a compressor. hook it up to some tubing and fan. Add gasoline as the refrigerant. Instant AC for cheap!
Run several of these past a fan.
Dude, you enjoy suggesting dangerous crap??Buy a compressor. hook it up to some tubing and fan. Add gasoline as the refrigerant. Instant AC for cheap!
You're not going to find anything that actually "cools" for $50... Maybe a used window AC unit.
Ok I will admit to being dumb at physics, but how so?
To my dumbass brain just having frozen stuff in the room with you should cool the room, fan or not.
Same idea if you make ice in the freezer then take the ice out, the heat was sucked out of the water and put in the back of the freezer as heat, when enough heat is sucked out of the water it turned to ice. Bringing that ice out is not going to counter the heat that came out of the back of the freezer.
Sure but what if the freezer is in a different room? Like I freeze the water bottles and ice pack at home and bring them to work to cool my office like that. I get my house would be hotter, but wouldn't my office be cooler?
Ice is so easy to buy already frozen it seems trivially easy to outsource the heat made to freeze the ice.
The peltier is still just a thermal transfer device, the hot side will be the same amount of heat that was removed from the cold side + electrical inefficiencies so it will not cool a room on it's own.
No matter what cooling technique you use it will require part of it to be outside or to continuously move the heat out of the house.
