what the max cpu i can support?
stevty2889
7,036
8
Well if he has 5 pci slots then it's not micro atx..now you have to figure out which revision it is..V2.0 supports 533mhz FSB, but V1.0 only supports 400mhz FSB..
theMan
4,386
it should be printed somewhere on the mobo. on mine, the revision number is between the pci slots. if you can find the model number printed on the mobo, it should be right next to that.
AnandThenMan
3,985
615
Why not download a copy of Sandra, it will tell you exactly what motherboard it has.
edit: nevermind someone suggested CPU-Z that will do the same job just not as detailed.
