what the heck is this antenna thing on my neighbors roof? pics included
Kenazo
10,429
Do they have a boat? maybe it's some sort of marine radio antenna.
And regarding the Wifi. Why jump to the conclusion that they're leeching right away? Maybe they have a network set up with some friends across town.
mercanucaribe
Banned
Oct 20, 2004
9,763
I don't think you can steal wifi with a cantenna... You can only transmit from one cantenna to another because they polarize the signal.
Falloutboy
5,916
thats not true, i've gone driving with my cantenna and I was able to hit networks quite well. granted you get better results if both sides are using a directional antenna its not required.
dmcowen674
54,889
47
www.alienbabeltech.com
Smart.
He probably tried an closed end can but it catches way too much wind.
He learned.
Thanks for the pics OP :thumbsup:
Staples
4,953
119
Well if this is a diy Wifi receiver, I'd be interested in knowing how one would make a directional signal transmitter.
Born2bwire
9,840
Just use the same cantenna for your transmitter then.
The polarization won't matter. Your wireless routers or receiving laptops use wire dipole antennas. The dipole's polarization is along the axis of the wire and the antenna in your cantenna is a vertical wire as well. A dipole can pick up circularly polarized waves, the only null is the plane normal to the antenna and even then all you have to do is angle the antenna to pick it up. So unless you're directing a null at your receiver, you'll pick it up (or just rotate the cantenna).
