what. the. fvck. - HELP!!!!!!
LED
6,127
Anything is possible but 1 things for sure ...good PSU or not ECS/PC chips are notorious for being picky about the PSU that is used...
wfbberzerker
10,423
do you think i should go for a different motherboard? it seems to me like its a motherboard issue... if it were ram i would think the computer would freeze or just turn off, not perform a shutdown.
LED
6,127
Choice is up to you as ECS has made a many satisfied Customers on my end but personally I don't use em...
wfbberzerker
10,423
ok, i emailed ecs tech support, and they said that it could be because the motherboard isn't correctly grounded. i dont see how that could be the problem, seeing as i had installed the motherboard on the risers correctly. anyhow, im gonna what nocturnal suggested and try it on a piece of cardboard. if that doesn't work, im saying screw it and getting a different motherboard.
thanks everyone for all your help!
LED
6,127
Tech will inform you anthing to RMA the as it's cost effective ;)
