- May 27, 2009
- 10
- 0
- 66
I currently have a Quad Core Q6600, 8GB DDR2 RAM, 8800 GTS 640MB (PCI-E), 2 DVD Burners (SATA), single SATA HDD (Possible upgrade to a 2nd), TV Tuner Card (PCI-E), Aircard (PCI).
I use both DVI slots on the 8800 GTS to power Dual 24" LCDs.
The PSU I had in it went out to lunch, and locally what I am finding for PSU options are the basic low end stuff I know wouldn't work, a few mid range such as BFGR550WGXPSU from BFG, or Antec Earthworks 650 EA650, or Thermaltake 550 W0134RU, or it jumps to the 850 range.
My old one was an OCZ 700W. I am not sure I actually needed the 700W or if I built it with excess power at the time for expandability. The computer is reaching the end of its upgraded life, other than possibly adding another HDD, I really don't plan on upgrading it further, next upgrade will likely be a clean slate build.
From my research so far it appears the Thermaltake is overpriced/underperformer, and the BFG is rated at peak not continious. Would the Antec Earthworks fit the bill?
Any guidance would be appreciated. Thanks
