What sides go well with Salmon?
JSt0rm
27,399
3,948
Thanks!
DO like, will make, down to using thyme instead of sage since I only have ground up sage and no leaves.
I already throw carrots coated in olive oil in to roast when I'm doing baked potatoes, which is relatively often. And I also often throw in an entire bulb or two of garlic --untreated in it's skin(s) -- for the last 20 minutes. Sometimes I roast an untreated onion as well.
^^^ Crude but effective (enough) guerrilla bachelor cuisine! :p
Did you know if you sliced the tops off the garlic and poured olive oil on it after 20 minutes you will end u with a garlic paste to spread on French bread? Add a bit of sea salt to it.
Just squeeze the cloves and the garlic will be soft and ooz out. Wonderful.
