What should I do, ATG? Turbo stuff
Loud or quiet?
  • Loud
  • Quiet
  • Meh
zerocool84
36,041
472
Where do you live where you can get away with this on a DD? I'd be scared to do this on my car.
Fenixgoon
33,388
12,991
He's talking about the wastegate, not the diverter/blow-off valve.
The wastegate diferts exhaust gas away from the hotside under full-throttle conditions to prevent overboost.
The diverter valve (aka blow-off valve) vents excess manifold pressure to prevent the turbine from stalling when there's a sudden lift of throttle.
Jlee: I would run the dump tube back into the exhaust somewhere downstream of the hotside but before the catalysts. That will keep you EPA compliant. An open dump lets exhaust bypass the catalytic converters and can get you into trouble if you ever have to smog the car (I know you don't have to now in NH, but you might move someday). Besides, the power difference is ridiculously small and while I'm certainly no tree-hugger, it just seems silly to bypass the cat for even a small bit of the exhaust considering how effective they are at reducing pollution.
ZV
at least in VW's, the diverter valve actually recirculates the overboost, rather than venting in (BOV)
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
951 does the same. Still, the fundamental purpose of the two types is the same. Both vent excess manifold pressure to prevent compressor surge/stall.
Really the the choice has more to do with whether the AFM or MAF is upstream or downstream of the compressor. If the MAF/AFM is after the compressor (or if you're using a speed-density or MAP system), you can safely use a BOV that vents to atmosphere. If your AFM/MAF is before the compressor, however, you need to run a diverter valve, otherwise you're venting air after it's been metered and causing a transient rich condition that's bad for the engine which can foul plugs or even destroy the catalytic converter over a long enough period of time.
ZV
jlee
48,518
223
ZV
Yep..my AFM is post-air-filter and pre-everything else, so venting to atmosphere is not the best idea. I'm running (and will continue to run) the stock recirculating BPV.
jlee
48,518
223
That sounds like a good excuse to do a gen 3 swap (speed-density). ;)
I actually did think about it, but it's not worth dropping $2k just to lose the AFM. I could do a Gen3 electronics swap, but then I'd be stuck with a Gen3 ECU which no one can tune...so I'd have to run a standalone to take advantage of my TD06/etc.
pray4mojo
3,647
One thing to think about, wastegates can leak a little and during long drives of little boost (say highway) they can actually draw atmosphere (cavitation effect? can't recall the name) in to the system and melt the cat due to the exhaust being to lean. I personally don't like the noise (and smell at times) and preferred to plumb it back to the exhaust system.
lol
exdeath
13,679
10
Recirculate the waste gate but install a 3"+ electric cutout on the down pipe, the you can have both loud and quiet whenever you want
uclabachelor
448
I have a TD06 20G & 38mm Tial wastegate that's going on my car - I'm trying to decide between running the dump tube into the downpipe ($150) or going open dump ($20ish).
If I send it through the exhaust, it'll probably sound about like it does now. If I run an external dump tube ('screamer pipe'), it'll sound more like this - (go to 1:05).
I love the sound but I'm afraid it will not only draw attention unnecessarily, but it may also get old after a while...
The dump tube will also provide you extra warmth in case your in-cabin heater isn't enough.
