what settings do u use to put 1.4 tb at stock speed?
Jun 19, 2001
27
I dno't think there's much you can do past overclocking to get the 1.4 you paid for. Good news is you will never see much of a performance difference.
DisposableHero
546
yeah ok.. was just making sure.. i will over clock later.. but i wanna just use it at stock speed for the beginning
Duvie
16,215
Your board rounds that up or the mobo is set to the default and then some factor of like 0.25 percent...you couldn't even clock it to it anyways...It is a product of the 133 not being like 133.333, just rounding error....
NelsonMuntz
1,827
It all depends on how far you want to carry the significant figures. The FSB is really 100 MHz + one third of 100 MHz which is 133.33333333333333, so the more digits after the decimal, the closer you get to your stock 1.4 GHz.
MCS
2,519
Do you have an Abit KT7A? If so I can explain why you are not getting a "clean" 1400Mhz.
fitzhue
1,242
MCS
I would like to know why anyways. Is that particular to just the abit board or what?
smp
5,215
My A7V reported my 900 (when it was running stock) at 907 using that AMD cpu proggy. On boot however, it would display 900. It's all frequency, it is never EXACT.. think of radio waves.. frequency.. microwaves.. volts.. etc.
MCS
2,519
There is a bug in the original KT7A shipping BIOS (WW) which sets the 133Mhz preset FSB to 133.00 rather than 133.33. It is fixed in the WZ BIOS onwards I believe, but if (like me) you still have the WW BIOS for whatever reason you can get around it. Set the FSB to the preset value of 130Mhz, and Set the Plus Mhz value to 3. This will give an almost perfect 133.34 (as reported by WCPUID).
TunaBoo
3,280
Set it at 134 if you really wanna be over 1.4GHZ. You won't tell the diff, but you will have more bragging rights.
