- Mar 8, 2003
- 38,416
- 4
- 0
title says it all, need the next step up from 1024x768 that will look the same, cept more detail. i like the current ratio of 1024x768, which resultion is a step up, but still has the same ratio?
Originally posted by: Naustica
1152x864 or 1280x960. Most people use 1280x960.
Originally posted by: gururu
Schadenfroh needs to study his ratios....LOL![]()
Originally posted by: Goi
You can also do 1440x1080
Originally posted by: KevinH
Here's a nagging question I've had. The same aspect ratio is 12:9 but why do just about all LCD's as well as reviews use 1280x1024.
Originally posted by: JBT
Though I'm not sure why some larger LCD's use 1600x1200 as that isn't a 5:4 resolution.
Originally posted by: Peter
Would you mind reading the thread? The tube you're looking at has a width:height ratio of 4:3, on which you're displaying 1280x1024 displays (a 5:4 ratio). Thus, pixels aren't square, everything appears squished.
Sure, the pixels are not square... but how many of you can actually actually see this. I certainly can't. An extra 64 pixels isn't even 10% of the screen space. Maybe if you had a wallpaper that was 1280x960, and it got stretched, then yeah, it wouldn't look right. Other than that... is it really that much of a difference? From my past experience with monitors, 1280x1024 seems to be the more widely available resolution (isn't it true that 1280x1024 usually has a higher max refresh rate than 1280x960?)
Originally posted by: TheSnowman
Nope, the refresh rate will always be higher with less pixels.
And regarding the squishing, sure I can understand that concept that things get squished. But take text for example. So say originally your text is 10 pixels high. If you use 1280x1024 instead of 1280x960, you get an extra 60 pixels (<10% increase). Ok, so let's round up, and say it increases the number of pixels by 10%. Your text is now 11 pixels high instead of 10 pixels high. Does it really appear that distorted? My argument is simply that a 6% increase in length for most things you display on your monitor is not a noticeable difference for me, with the exception of maybe a wallpaper displaying a person's body/face.Originally posted by: TheSnowman
As for the squishing, that goes text, games, and everything else just as much as it does for a wallpaper.
