stopped reading here since you obviously did not read my post; making that statement and i'm assuming all that follow completely needless.
i didn't saying regen braking didn't slow the car down. i said that the PRIMARY EFFECT is to charge the batteries, as that is the only time that the power produced (notice the past tense) by the engine is not being utilized for a different purpose. toyota is not trying to help your prius brake, they are trying to help your fuel economy. your argument is basically that because my car has a manual, the message center should automatically say 'hill descent mode' when i go down hills in low gear.
edit: ok i caved and read your post. you're agreeing with me on the use of regen braking- ideally (in an energy conservation sense), you want the car to roll as long as possible at speed without throttle input.
but yet again people want to pick fights based around semantics and escalate them into arguments where no one disagrees.
I was agreeing with everything you had said except the misnomer thing. I was just trying to elaborate.
The purpose of regenerative braking is braking. That's why its called regenerative
braking. It's just that instead of wasting the energy as heat, it tries to recapture and store some of it.
Regenerative braking
is by nature a system to help you brake. The drag on the drivetrain is a direct result of converting kinetic energy into electricity.
It serves the same purpose as friction brakes. Theoretically, an electric car could do away with friction brakes all together. A motor acting as a generator is perfectly capable of locking the wheels if it was designed to do so.
Look at it this way; if you replaced the battery with a large resistor in a regenerative braking setup, you would still be wasting the energy as heat just like with friction brakes. You wouldn't be regenerating anything, but you would still be braking with the generator.
The only thing I disagreed with was your statement that regenerative braking is a misnomer. It is not.
Edit: Helping your fuel economy is the after effect, not the braking itself. Theoretically, a regenerative braking system could charge your 12V battery. This wouldn't manifest itself as increased fuel economy, but it would still be regenerative braking.
I was not trying to argue with you at all, I was trying to have a discussion about something that is part of my every day vocabulary and that I'm quite familiar with.
