Hey Zeus
Banned
- Dec 31, 2009
- 780
- 0
- 0
If you are on a budget and don't have a Microcenter near you to get a better price on the 920 or 860, I would say go for Core i5 750 for $200 + $135-$160 mobo in the likes Gigabyte P55A-UD3 or Asus P7P55D-E. EVGA is good too. I would not get an MSI board over these 3 though.
So you have $90 savings on the processor vs. 860/920 + $25-$50 savings on the mobo over X58 and another $20-30 savings on the ram:
http://www.newegg.com/Product/Produc...ll+eco&x=0&y=0
ECO line only requires 1.35V. This is probably the best DDR3 ram out right now. In general G.Skill kits this round provide great bang for the buck with low voltage requirements. If you don't know how you can benefit from 6GBs of ram over 4GBs, then you clearly don't need 6GBs of ram just yet. Plus you can always pick up more Ram for 1156 later (it supports 16GBs, more than enough).
Even if you consider the lowest savings you can get that's $135 over an equivalent 920 setup. Take this $$ and put it into an Intel SSD or get yourself a faster videocard.
Also, the good EVGA P55 board is the EVGA P55 FTW SLI edition. Since there is not a single compelling NV card out right now for the $, you are paying $210 for SLI option you won't use (are you seriously going to SLI GTX 260/275 with Fermi?). Getting 2xGTX 260 is also a waste since you can instead get a single 5870.
That's why I recommend you go for the other 2 boards I posted (any of these boards will more than max out the 750 on air cooling, so why pay more than $150 for a P55 board?).
FTW is probably the best overclocking board next to the FTW 200 and the Classified
 Facebook
Facebook Twitter
Twitter
