what power supplies are you running ?
rh71
52,844
1,049
Antec 300Watt PSU and I run the following:
AMD Barton 2800+
Abit NF7-S v2.0 mobo (latest BIOS)
OCZ 512MB PC3200
Sapphire ATI 9800 Pro (latest catalyst drivers) - this is a bear, I hear.
2 HDDs
DVDRW
DVDRom
So what cha think ? I may have to get a new one... what's the minimum I should be at ?
jhurst
663
I would suggest at least 350-400W with a 9800pro....especially if you are overclocking..
Enermax 460 here....great PSU!
thetman
216
antec trueblue 480w, rma'd the first one cuz it had bad voltages, but this one works fine
rh71
52,844
1,049
the machine is off right now since it's shutdown on me 4 times today...
I do know that the -12V rail was constantly out of range (-13.00 max and the value was always -13.27). THOUGH, I heard the -12V was no longer used on newer boards... is this true ? I just disabled the alarm. Everything else was in range according to ABIT EQ.
saxophonoia
2,835
right now i'm using an antec trupower 430w that works well but I think i'm going to upgrade soon to around 530w or so......i'll probably stay with Antec
jagec
24,442
Antec 350 (or is it 380? never can remember) with mobile 2400+ @ 3200+, 1GB RAM, 9800pro, raptor, HDD, CDRW, 4 fans.
rh71
52,844
1,049
Originally posted by: Fern
See my sig for PSU
Here's a psu calculator. Type in what u got, and it'll tell what u need PSU Calculator
You rock.. that's a great link.
It says I should have at least 355. OOOPS :D
Just ordered the Thermaltake 420Watt for $39. (can't afford much right now) Thanks for the recommendations.
n7
21,281
4
Originally posted by: McArra
TT purepower buterfly 480W here. Really satisfied with it.
That's what i was gonna buy went i went to get mine, but they didn't have stock of it, so i went the the TT Silent PurePower 480W
MegaWorks
3,819
Antec TrueBlue 480W
AMD Athlon XP T-Bred B DLT3C 1700+ @ 2.3GHZ (1.775v) 400FSB = 3200+
Abit NF7-S V.2 (nForce2-U400)
Corsair TwinX XMS 3200LL 512MB @ 2-3-2-6 (2.6v)
Sapphire Radeon 9500 Pro 128MB
Antec TrueBlue 480W
Thermalright SLK-947U with 92mm Vantec Tornado @2800RPM
Antec PlusView 1000AMG
Cambridge SoundWorks MegaWorks THX 550 5.1
MichaelZ
871
Globalwin Sapphire 520W. Upgraded recently, previously powered by Enermax Noisetaker 470W.
Soulkeeper
6,739
156
that link recommends i use a 444 watt psu (seems a little high on the hard drives and not enough on the cpu/mem) :)
of course we both know that overclocked components use a good amount more juice too
good link listed above btw
jagec
24,442
Originally posted by: Big Lar
I run a PCPower and Cooling 840 Redundant. I likes my power :D
holy crap....I guess you do....sounds like a really big file server to me?
