what power supplies are you running ?
Jen
24,206
14
Originally posted by: Big Lar
I run a PCPower and Cooling 840 Redundant. I likes my power :D
WOW
i run the 510 watt version after my trade in of my 450
Jen
edmundoab
3,223
www.facebook.com
Enlight 420W and its been doing an awesome job for me.
I upgraded from a 300W to this about 1 and a half years ago.
At current , if you are able to acheive stability at 300W I think its already the bare minumum you can stay.
Try going 400W above at this point. Then your 9800pro can enjoy the power it needs ;)
Shimmishim
7,504
Originally posted by: Soulkeeper
antec 550 truecontroll
gotta keep those rails strong :)
antec truecontrol 550 sucks to be honest...
the voltage pots to control the rails barely raise the voltage at all...
i saved the money and got an antec 430W truepower and modded all the rails myself so i get 3.3, 5.2, 12.4
Shimmishim
7,504
oh yeah and i've also modded someone elses truecontrol 550 cuz they weren't getting the voltages they needed by the adjustable pots...
Thor86
7,888
7
Antec Trupower 550. No problems whatsoever with any of the latest hardware plus 4 SCSI drives and 2 IDE Optical drives all powered from it.
earthman
1,653
Antec Truepower 550.
TruePower from Antec is the most advanced line of PC power supplies from the company that has led the way in power supply design and quality since 1986. These power supplies feature dedicated output circuitry for each voltage so that each output delivers maximum power whenever you need it. To make sure these voltages stay accurate, TruePower also includes voltage feedback circuitry to improve system stability
jswjimmy
892
enermax 300w
runing
amd xp1800@2.2ghz
shuttle an35n-400
adata pc4000@440mhz
gf2
maxtor ata133 7200rpm dimondmax8
crd-rw
5 case fans+hsf
neon
floppy
no power problems yet
Lyfer
5,842
Originally posted by: twajetmech
I run a PC power and Cooling 510 deluxe...love it !
Those suckers are expensive. I wouldn't spend more than $80 a PSU unless the rig REALLY needed it. If your not overclocking any good quality 350W psu should be able to run most rigs fine. I vote for the Enlight 420W, only $39 and should be able to handle anything you throw at it.
Acanthus
19,915
ostif.org
Antec Truecontrol 550w.
Extremely pleased with it.
I would strongly suggest an upgrade, but if you want to check for yourself, just watch an MBM under load.
Acanthus
19,915
ostif.org
My rails are just fine with that PSU.
12.159
5.107
3.376
nealh
7,078
I have an ANtec TruePower 480W..I have had it for at least 1.5yrs now...
my 12v..11.92
5v ..........4.95
3.3v........3.26
Now:
P4 2.4b@2.9 at 1.625....actually 1.6v
1gb Kingston valuram(pc2700 2.5v) but runs pc3200 2.6v 2.5/3/3/6
cpu/fsb 4:5
9700pro 351/331
hhd 2x 160gb maxtor
dvdrom
dvdrw
cdrw
audigy 2
adaptec 2906 scsi card for my scanner
I tried to go back to 166fsb but the cpu is not liking it at all..crashes in games and even in winxp pro now...I guess the cpu is the limit..when i bought it was tested to run at max 2.95..I have not tried going up to 162 as it needs more voltage so I am happy for now
I was able to in winter of Florida able to run my P4 2.4@3.0 with pc2100 crucial ram at 166fsb..with some issues in games starting in Jan after 1 yr...
My system then:
P4 2.4@3.0 166fsb at 1.725..this mobo reads .25 v high
512mg crucial pc2100 cas2.5/3/3/7 at 166 1:1
Abit I7Max2 rev2
9700 pro 351/331
aureal vortex 2
adaptec 2906
dvdrom
dvdrw
cdrw
3 hdd for awhile, but then went to 2 x160
Now I hear these Antec TruePower are not great for O/Cing P4's...since the 12v line is just ok...so now I wonder if I should try and get a quiet 500w PS for my future needs
HardWarrior
4,400
23
Vantec stealth 520w aluminum, 3 fans. No problems with it after 18-months, plus it matches my black aluminum case. :)
ectx
1,398
2 antec tc550. Enermax 465(?). Antec 300 (forogt which model). SPI 300. SPI 250.
Also a 400w psu that canme w/ the case - wned dead in 1 month.
NokiaDude
3,966
Antec SL350 running:
AMD Barton 2500+
512mb Kingston HyperX DDR333 RAM
16x Lite-On DVD-ROM
52x ATAPI CD-RW
80gb WD SE HDD + 120gp WD SE HDD
2 High-Output Sunon Fans
Abit AT7-MAX2
ATI Radeon 9800 Pro/ Zalman ZM80C-HP VGA cooler
Creative Audigy2 ZS
2 3/40mm fan bay coolers
Rock stable.
