- Jun 23, 2005
- 15,881
- 4,877
- 136
Trying to build as good a rig I can on a strict budget of $700-$870. This isn't for gaming, so unless a $300 video card is essential for video rendering I'd like to skimp on it and focus my budget on other parts. My biggest question is what cpu type is best. On the one hand, AMD's cheapest dual core would be better for multi-tasking, but on the other I hear AMD Opteron's are best for rendering. (Like in Georgies case for Revenge of The Sith) http://www.findarticles.com/p/articles/mi_m0HNN/is_6_20/ai_n14795229
So what is the better cpu for this build? Dual core, or Opteron? What kind of PSU will I need? Antec has a case/350w psu combo for a good price, but I'm not sure if it will be enough.
http://www.newegg.com/Product/Product.asp?item=N82E16811129150
As for RAM, I can imagine 2gb's of ram is better for a rig like this then 1. I'm just not sure if I can fit it in my budget. I guess I'll be going with Corsair Value ram, I'm just not sure how much of it I can get to stay withen my budget.
Here is a basic rundown I threw together just to get started.
http://www.newegg.com/Product/Product.asp?item=N82E16827152047 NEC DVD burner
http://www.newegg.com/Product/Product.asp?item=N82E16811129150 Antec Case w/350wpsu
http://www.newegg.com/Product/Product.asp?item=N82E16822148015 80 gig HDD
http://www.newegg.com/Product/Product.asp?item=N82E16813123236 Epox Socket 939 MOBO
http://www.newegg.com/Product/Product.asp?item=N82E16814130241 EVGA 6200 Video Card
http://www.newegg.com/Product/Product.asp?item=N82E16820145440 1 gig of Corsair Ram
http://www.newegg.com/Product/Product.asp?item=N82E16819103562 Athlon 64 X2 3800+
Total: $728.13
The build assumes I go with a dual core, however I really don't know much of anything about opteron or what parts are best if I end up going in that direction.
Just what kind of video card is really necessary for a rig like this? Do I have to go with something better? And how does the X2 line fare against the Opteron line for a Video Rendering system? Advice would be appreciated.
Total: $728.13
