Originally posted by: geno
Originally posted by: Sluggo
Motor oil is motor oil.
heh, good one 😀
I just adjusted my valves and noticed no buildup or clogged ports after 5k+ miles on the oil. Also, compression was at least 190psi on all 4 cylinders, so no abnormal wear from broken polymers. What tests did you run? Or did you see some oil comparisons on the Exxon/Mobil site?I NEVER use Castrol. Have seen to many problems of it caking up and sludging up the engine to bad. Did some research and found their polymers they use enlarge faster than other oils which cause them to break down faster, esp if you don't change your oil enough.
Originally posted by: slikmunks
castrol gtx 20w50
my manual says to use 20w50... synthetic vs. dino is no real difference to me or my car
Originally posted by: KennyH
So Marlin1975, is Havoline OK or should I change to something else? No, I am not planning on switching to synthetic on a 164K engine. I have removed the valve cover recently to check out the cams, vavles, etc and it was the cleanest engine I have ever seen with 164K on the clock. Seriously, no buildup whatsoever. My bro and I had a Olds' Cutlass a couple years back that we bought used and literaly had to take a flathead screwdriver and hammer to the areas around the valvesprings due to the massive buildup.
On another note, my father got his degree in auto mechanics (back in the day) and has pulled valve covers before and the heads have a complete imprint of sludge buildup on it as high as the valve cover! :Q This was after a customer used Quaker State for a number of years (some 20 years ago this was). To this day, he will NOT use Quaker State in anything we own. Even our lawn tractor. 😛
Originally posted by: machintos
Mobil1 synthetic...
because I used pennzoil before and my engine started sounding rough.
I started using mobil1 and everything is A-OK 🙂
Originally posted by: Pilsnerpete
What's the best non-synthetic oil to use? I've heard that if you switch to synthetic after running normal in an engine for years, it eats the seals. So maybe Valvoline Old Car? I think I'll try something else cuz mine's running rough...really rough.
