What monitor does everyone use?
Doomguy
2,389
Mitsubishi 2070SB
I'll never settle for the picture quality an LCD provides. My next monitor will be another old CRT or an SED monitor if they bring that technolgy to computer monitors and not just TVs.
JRW
569
Originally posted by: moonboy403
not even the almighty dell 3007p?!
Size doesnt mean everything as you still get all of LCD's negatives, besides the 3007 has no connectivity ,Only a DVI port which means no Xbox360..also it's native res is way above 1080i which means even if you did get Xbox360 hooked up it wouldnt look very good due to interpolation. And as for PC gaming people are fooling themselves if they think current hardware is going to run everything fine at 2560x1600, I prefer running a midrange resolution with all graphic details enabled & maxed.
Nirach
415
Apple 20"
No, I don't game at the same res. as my desktop. Well. I do play GTAVC at 1680x1050, but that's the only one. And the only one installed.
If you're using XP, set it to the 1600x1200 and try setting the fonts, I think that option is under the same place you select your olive/sliver/generic blue XP skins in, to large or extra large, in failing that, go to the 'advanced' options on that taba nd mess with the font sizes in there.
Rottie
4,795
NEC MultiSync 5FGp 17 inches monitor with 1024x768....very OLD monitor
justlnluck
261
Originally posted by: nib95
Dell 2405FPW for my PC (soon to be a 2407FPW, free replacement).
XPS Gen 2 WUXGA screen for my laptop.
How are you getting a free replacement??
Mucker
2,833
Mitsubishi 2070SB............high speed gaming
Benq FP91G+..............crystal clear DVI
sheltem
622
NEC 1760NX - Display #1 (Gaming)
Samsung SyncMaster 173T - Display #2
I'm planning on going with a 20 inch widescreen whenever I can afford it.
BoomerD
66,282
14,703
Heh...STILL plodding along with my 8+ yr old Sony CPD 420GS CRT monitor. Won't give it up till I have to.
rbV5
12,632
My Main PC primary display is an old 22" Mitsu CRT running a 1600x1200 desktop, soon to be replaced by a used 24" Trinitron CRT.
For my bedroom PC, I use a 27" 720p Viewsonic LCD display running native 1280x720 desktop.
I prefer a CRT display, to the point of purchasing a used CRT to replace my dying main CRT. I had to use LCD for the bedroom, and I like it for what I'm using it for. My CRT RPTV will eventually be replaced by a projector, likely not CRT based as well.
ddogg
1,864
361
HP A7217A 24" CRT(same model as the Sony FW900) Widescreen running desktop at 1920x1200.
chilled
709
Hansol 920P 19" CRT. About 3.5 yrs old now. Running at 1280x960.
I really want a 2407FPW, as long as its kinda decent. Just need to wait until I start my job in Sept...
