What mini-ITX motherboard to pair with Ryzen 5 2400G?
I vote for the Asrock B350 itx/ac as well. I just got my combo at newegg from fedex 10 or so minutes ago and ripped into the packaging as fast as humanly possible.All I can say is it is amazing looking in person and online pictures dont do it justice at all. It is so tiny and so beautiful.Also I can confirm they are now coming with updated larger vrm heatsinks instead of the smaller one with the giant pillow foam that was causing all those overheating issues back in Sept. on and around release.This is my first Asrock board and wont be my last after this.I wouldn't even touch that Gigabyte board with a 10 foot pole due to its god awful layout.
You do know you have to use the Wifi drivers from the Driver disc included in the box and not the Windows 10 drivers from Windows update right?
If you are using the Windows 10 driver uninstall it asap cause that is where your issues are..
I dont have any issue's yet knock on wood so I'm really not sure what your talking about!!
Also I am using a R7 1700 and not a APU. If you are using a APU maybe try running in AHCI Mode and not in IDE mode.
The issue is their 4.40 BIOS is crap and causes BSOD's when using the WiFi. Unfortunately with Raven Ridge (which was the OP's question) , that's your only BIOS option and therefore it's a bad option.
I had issues too, with UEFI version 4.30 and 4.40 for AB350M Pro4, with my Ryzen 1600 CPU. But 4.50 was seemingly mostly golden for me. (Can't set XMP on my DDR4-2400 RAM though.)
Personally I'm not touching a beta BIOS that's a day old. Especially since this is their 3rd attempt at making a stable BIOS for Raven Ridge. Plus that BIOS was posted after your vote for the board.
Yeah which means I liked the motherboard before they rolled out an update... besides I am still running Bios 4.40 with a r7 1700 not a 2200g or 2400g and im not having any issues at all. First time I powered it on though, I got a 3 times reboot cold boot loop, but was quickly fixed by making some changes to some bios settings. One of them was to change Ide mode to AHCI mode.Also turned off a few other options not being used including bluetooth but not Wifi.I think it could be a issue with the motherboard confusing the bluetooth and wifi and causing everyones issues.
