What kind of surge suppression should I use on my 52" LCD?
MBony
2,990
I have an Aquos Sharp 52" and I was looking for suggestions for what to use? Is battery backup an option or is it too big?
BigJ
21,330
Decent surge protector will be fine.
Something that is getting popular is whole house surge protection. Not expensive at all (ranges from $70-couple hundred dollars for the unit) and relatively simple wiring (depending on how experienced you are). It's a moderate DIY project.
Captante
30,342
10,860
I run my 37 inch Toshiba LCD off of an 800va APC which I got uber-cheap & its more power then it needs.
MBony
2,990
On these APC units when the power clips, does your LCD turn off or notice the disruption in any way?
isekii
28,578
I use a 600va UPS on my 42" Aquos.
I don't lose TV or notice any disruption when the power clips
jpeyton
Moderator in SFF, Notebooks, Pre-Built/Barebones
Moderator
Aug 23, 2003
25,375
142
Get a Monster Power Center from Best Buy, and get it installed by Geek Squad.
MBony
2,990
Originally posted by: FoBoT
the specs on the website say "270W" , so a modest sized UPS would work, something like a 600 VA model is good
like this one
http://www.newegg.com/Product/...x?Item=N82E16842164001
$34.99 + $12.14 shipping
http://www.sharpusa.com/produc...s/0,1161,1744-,00.html
Not a bad price either. I have a 360, Wii, and HD-DVD that I'd like to have plugged in as well. None of these run constantly, but I'd like to be able to plug them in for protection. Would the Rosewill support those as well?
RossMAN
Grand Nagus
Feb 24, 2000
78,942
403
the $299.99 one or the $399.99 one ?
Whichever offers a product replacement extended warranty plan.
Captante
30,342
10,860
Nope ... never been any kind of problem at all, even when I had a brief complete power failure a few weeks ago.
The picture & sound went off because the cable box isn't connected to the UPS but there was no loud pop from the speakers & the LCD itself stayed on.
Rio Rebel
Administrator Emeritus<br>Elite Member
Actually, the best combination is Monster power center with a Bose system. They are optimized for each other.
PurdueRy
13,837
4
But you have to use the Bose® PowerBoost+® Cable to connect them together so the Acousticable® system can properly control the Waveglide® technology.
Young Grasshopper
1,032
380
i will have a pioneer kuro 50', playstation 3, samsung reciever and directv hd tuner, how many watts should i be looking at for a ups? is 600 enough?
Jugernot
6,889
My guess would be:
Kuro 300watts
Playstation 3 ~200watts
samsung reciever 250watts, which bursts of higher wattage depending on what you're watching
Directv tuner ~50watts
kalrith
6,628
7
My guess would be:
Kuro 300watts
This is probably pretty close to reality. I have a 50" Kuro and DirecTV HD DVR connected to a 450W UPS, and it stays at 4 out of 5 bars of load when the two are running. It didn't have enough juice for the Kuro and PS3.
ultimatebob
25,134
2,450
You fool... everyone knows that you need the Platinum plated $100 MonsterPower cables for best results!
Exterous
20,565
3,752
Only $100??! Why did you cheap out on your cables??!! Don't you know that you won't be able to pass 197Hz 12876x12760 resolution with 76bit deep color father than 2in with those cables?
