- Mar 28, 2004
- 7,613
- 3
- 0
Going to change the oil in my car and I thought that maybe this time I should consider the advice from the people of ATOT. So what would you recommend?
Originally posted by: MulLa
synthetic - Castro Edge (was told Castro was better for Toyotas)
Or Castrol.. Buy maybe Castro is better..![]()
Hey, I'm a believer here. Amsoil makes a huge difference in our dragsters transmission and rear end. Don't be a hater until you've stressed it yourself.Originally posted by: CFster
Cue the Amway scheme Amsoil pushers...
Originally posted by: bwatson283
If you already use a Full synthetic, then you have to continue using it. It is recommeded that you continue using the same type and weight all the time. It is like sleeping with two different women, you wont get the same results, and your machineary will be hurting.![]()
Originally posted by: Baked
Mobile 1 bitches.
