What kind of deodorant do you wear and how much does it cost?
ivory soap
i take a shower at least once a day,
i found that,that is all i need to keep from reeking.
Same reason i don't wear cologne/perfume,because i wash up~!
btw do a search,LOL there has been several deoderant,nd,cologne threads of late.... 😉
did not see any asking the price tho,
I can't believe nobody has mentioned Arm & Hammer.
They're by far the best I've ever used. I buy them on sale when they're 2/4$..
old spice high endurance.
good stuff.
i dont know how much it is 3.50
its the only kind that A. actually works and B. doesnt give me "pit burn" or some burning sensation, whatever its called.
Just started using one of the new Speed Stick "24/7" gels. My girlfriend didn't like the smell of my old deodorant so she helped pick this one out. I think it was 4 bucks or so.
Originally posted by: Marlin1975
You do all know that 99% of all deodorants use the SAME active ingredient right. It is called Aluminum Zirconium. It will range in %'s but not much.
I looked into years ago, as they are always some add saying they are better etc... So I looked it up, and they are pretty much all the same. So save yourself some money and get the cheapstuff. I use speed stick. Like 2-3 bucks a pop and works juts liek the $5 and $10 sh!t.
I heard that Aluminum Zirconium is really bad for you.
Anyway, I use Acqua Di Gio deoderant that I get in the gift packs. I had a new one also, but I lost it, I think it's about $15 bucks separately.
This is true, however... aluminum zirconium tetrachlorohydrex gly is only an anti perspirant.
It has nothing to do with the other qualities of a deodorant.
Yea anything can be bad for yu. I am juts saying there are a lot of stupid peopel out there going "Well I only use xyz as it is the BEST" when just about every one out there uses the same thing. The only real diff between one or the other is smell, which does not last very long, and price.
So I buy the cheapest stuff as it does the same job as the others.
