What is your opinion of the Chevrolet Volt?
AdamK47
3,638
GM makes terrible vehicles. I'm not sure why anyone would consider buying a Volt.
herm0016
8,524
1,132
When your at a light does it just blow cold air? That's been the tell for us. We'd have the heat going and stop at a light and bam, cold air.
No, seems odd. Are you in eco? The hvac in ours works like you would expect it to. I usually just use the heated seats because they are a much smaller load on the battery. sounds like the people selling the car did not check it out well at all. A lot of people are very misinformed on Volts. The heat does throttle to save energy, so if it is getting close to the set temperature, the air will get cooler to maintain that temp and use less energy. In a car when the engine is running, only the fan speed changes, not the output/temperature of the heater core. another way to know if the heat is working is to see the wattage being used on the dash when sitting still, the heat is 5 kw max I believe. These cars take a bit of getting used to.
Even the radio amplifier is a special, patented, low noise switch mode instead of linear to save energy!
I am not sure why a lot of people buy a lot of things. Take your fanboy attitude right out of the garage. Volt has been Highly rated from its inception.
Herr Kutz
2,545
242
It takes about 50% more energy to push an Equinox down the road, so it would need an upsized engine and a battery that's 50% larger (and 50% more expensive), otherwise it would have a lot less EV range.
If this were a valid response no manufacturer would make an SUV to begin with because it requires a more powerful engine to push the SUV. All they need to do is offer a PHEV SUV that has best in class fuel economy, not best out of all other (regardless of type) vehicles fuel economy.
AdamK47
3,638
I agree... As I still own one of the terrible GM's. That said, the Volt seems to be the exception to that rule.
They make some of the worst cars for fuel economy. I currently own a GM car and average only 12 MPG. That's just terrible.
Yuriman
5,530
141
The reason is cost. EV costs scale up considerably more than ICE vehicles when you're trying to maintain the same range.
Apr 20, 2008
10,067
990
Not in Eco, in comfort. I tried every setting imaginable. It was only doing .5kw on the dash and was 100% climate power. Heat at 90/Hi. Cold fuckin air.
Update on the dealer situation: Charge issue covered under warranty, heater issue TBA. I'll know more details when they call me back.
SearchMaster
7,791
114
Psssst - he owns several GM products (Vette and/or CTS-V if I'm not mistaken, plus a lower end like a Sonic or Cruze).
Meghan54
11,684
5,228
I figured as much, given the "I currently own a GM car and average only 12 MPG." comment. Hell, my truck averages 18....gotta really be flogging something to get down to 12 these days, or be driving something "big".
Apr 20, 2008
10,067
990
Update: Charge issue covered under warranty, fixed today. Heat module(?) failed and is being replaced. I'll get the car tomorrow after it is completed. that is being covered by the dealer.
I looked at my OnStar and saw the car hasn't been charged for 600+ miles, long before the car was sold to a dealer at auction. I used this in my justification on why the car wasn't clearly inspected first. If you had plugged the car in and checked all electrical mode, they would have seen this charging and heating issue. Do you agree?
AdamK47
3,638
It's a Malibu. I think part of the reason for the poor gas mileage is due to a misfire. It also often times makes loud backfiring noises. It's only a 2015 and yet this GM junk already falling apart. Here's a video I took of it that shows the issue: https://www.youtube.com/watch?v=yeUnU2R4gXk
herm0016
8,524
1,132
Agree. Glad they are getting all fixed for you. Dealers suck.
Yuriman
5,530
141
Our's gets 35mpg on the highway and that is with the pushrod V6(3500).
Is that via the (likely very optimistic) factory gauge, or measured at the pump?
I drove a Chevy Express 2500 for work for a while, and on a long trip I could reset the gauge when I filled up, drive until the tank was empty, and see "22mpg" on the gauge, whereas the miles driven divided by gallons used would generally be 16-17, an error of nearly 40%. By contrast, my Insight's instrumentation is generally within 0.2-0.4mpg (e.g. 68.1mpg vs 68.3mpg) over 6-800 miles.
BurnItDwn
26,371
1,879
Ahh, see, you are counting the time spent on the entrance ramps and accelerating and local traffic too :)
"on the highway" he might get 35 ... if he maintains constant 50mph speed and doesn't go up any hills or speed up at all :)
Elixer
10,371
762
Was at the dealer today, getting recall work done, and the guy next to me has a Volt, and he goes, his insurance shot up 3x from what he was paying before, and they said the main reason for the much higher cost is if those get in an accident, special care must be taken because they need to test the battery packs individually, and that is a ton of work.
Anyone run into high insurance rates like this guy?
Yuriman
5,530
141
Sounds like nonsense to me. Nobody tests Prius battery packs individually, and it's essentially the same, just smaller.
fleshconsumed
6,486
2,363
Did he shop around for a better insurance deal? Different insurance companies can have vastly different premiums.
WackyDan
4,794
68
Nope - that is verified at the pump from fill up to fill up. It's an 05 Malibu so those things were not as heavy as the other models sporting the 3500 V6. In and around town it sucks though.
Apr 20, 2008
10,067
990
Nothing crazy. My insurance went up from $140 to $180, but I have a $200 deductible and this car is blue booked at nearly 3x the price.
Apr 20, 2008
10,067
990
All good, getting a charge in each night with the portable EVSE charger. I snake it through an unused switchbox that I deleted from my shed/carport to securely charge it. I don't live in a good part of town and there's no way to rip the base through there.
The 8amp charging seems fast enough. Haven't used more than a half gallon of gas in a week. Electric-only drive is awesome.
Reactions: herm0016
Apr 20, 2008
10,067
990
Since everyone wants an SUV I'm still trying to understand why they don't offer an Equinox version.
I feel like this would work for most people even with the same electric battery. Up the motor to 2L and you've probably got it matched properly for hybrid mode. How much more weight would an SUV version even be though? Between the Cruze (Volt frame) and the equinox it's only a 500-800lb difference.
My 2014 Volt weighs the same as the Equinox.
tweakmonkey
728
32
tweak3d.net
It only charges at 8 amps? Can you select 12 somehow? Most the evs I’ve used have both modes or default to 12.
Herr Kutz
2,545
242
It absolutely would and they wouldn't even need a battery with a ~50mile range. Just enough to cover sitting in the kid dropoff/pickup line at school and driving the 2 mile round trip to the grocery store that the majority of these will be used for. I think it could be workable even if all electric range was 20 to maybe 30 miles.
