What is your air cooled cpu temperature right now?
SuperCyrix
2,118
I'm at 29C/84F on my air cool Duron.
System temp is 30C
I can get this much lower if i switch to my old socket 7 Cyrix MII300 and even lower on a K6-2 400 and probably room temperature on the Pentium 133.
Room temperature right now is about 68F in my room
Does anybody have one of those newer Cyrix chips, I heard those run really cool.
snow patrol
8,377
Board temp is 40c and CPU is 50c. This is running an overclocked P4 2.2ghz at 1.7v with SETI at full pelt though :)
Kadarin
44,296
16
CPU is at 51 degrees Celsius, while the board is at 28. Asus A7V266-E w/Athlon XP 1800+ (at 140FSB) running Alpha 8045 cooler.
snow patrol
8,377
Am I right in thinking my board temp is a bit too high :(
I've got a coolermaster case with 4 case fans. Not quite sure why it's this high..
SuperCyrix
2,118
where exactly is the thermal diode that reads the system temp?
Wish I can attach one of my old socket7 heatsinks on the chipsets
SuperCyrix
2,118
You guys are comfortable with 50C+ temperatures. Wow, I remember when I use to freak out when I saw 40C.
I guess 50C is like running your pc in Arizona without any ac in the room.
jjones
15,424
CPU temp: 59c on my oc'd t-bird
System temp: 38c
I need to put on some new thermal paste because it should be running in the low 50's.
Amused
57,352
19,530
MBM says:
P4 2.0A temp: 34c (no real load right now)
Mobo temp: 28c
Room temp: about 75F (24c)
SWScorch
9,520
Mobo: Asus A7V
CPU: AMD Athlon Thunderbird 1.0GHz @ 1.3GHz
Room Temp: 22 C
Mobo Temp: 27 C
CPU Temp: 44 C
This is with an Alpha PAL8045 and a 50cfm Sunon fan, running ECCp-109 right now.
dakata24
6,366
40*C Cpu Temp
29*C Case Temp
on my Athlon XP 1700+ overclocked to 1.628Ghz
i hear those cyrix chips are able to run just using a heatsink (with no fan)...
Justin218
2,208
Duron 750 @ 120F with a HSF with a rheostat and only a PSU fan. Usually runs around 114, hmm. If I turn the rheostat all the way up and it's a cooler day in the winter (I live in Fla, a cool day is 65) I go below 100.
Czar
51°c using a GlobalWin silver orb on AthlonXP 1800
Heatsink temp 38.6°c
Between 80gb and 60gb hd 30.1°c
Between 60(or 80)gb and 11.5(or 6.5)gb 26.4°c (forgot how they are set up exactly in the case)
Bottom part of case 32°c
Top part of case 25°c
Room 25.8°c (seems a bit high)
cmdavid
4,114
how do you all get all these temperatures?? i have coolmon but from what i can tell it doesnt monitor all this...
yakko
25,455
I don't know but the flames are smaller than normal do to light usage today.
Thegonagle
9,773
I don't know. My old-ass motherboard doesn't support CPU temp monitoring, but because this thread had me curious I rebooted and checked the system temp through BIOS. 107F (42C) in the case! It must be about 90F here in my living room. And I still can?t justify buying myself a window AC, because I?m such a tough guy, ha ha!
tk149
7,253
Room: 21.8
Mobo: 32
CPU: 39
AthlonXP 1800+, no o/c, running SETI as I type.
Thegonagle
9,773
Damn the metricisms!
I made that word up. :D
What's my 90F room temp in Celcius, about 35-36?
Thegonagle
9,773
Well, 107 is too, too, hot!
My system (OC'd Celly 566 at 850) running XP just BSOD'd.
I'm turning this sucker off until tonight. Sorry, SETI team!
pac1085
3,456
138 F idle heh....been running rock solid at this temperature for a year and a half though...could care less if it dies, would give me a reason to upgrade :p
