What is the Soul?
FoBoT
63,082
12
fobot.com
Jeff7
41,596
19
the soul is an immaterial substance, hence it is not possible to locate in one's body, though it is closely related to it. a good question to ask is how something immaterial, like the soul, can interact with the body. if you find the answer let me know :)
And if it is capable of interacting with the body so regularly, and so forcibly, why is it so consistently and utterly impossible to measure or quantify?
Braznor
4,619
409
The word 'soul' is a mythical religious concept.
The word 'consciousness' is a modern term trying to explain the unitary experience of cognition of higher ordered living beings.
All in all, I do believe the key to consciousness is rooted in the mysteries of Quantum mechanics. A possible location for this phenomenon could be based within the microtubulin molecules inside the cytoskeleton of our neurons. These microtubules could be the prime candidates for Quantum processing inside our brains.
http://en.wikipedia.org/wiki/Orch-OR
Hameroff proposed that microtubules were suitable candidates to support quantum processing.[24] Microtubules are made up of tubulin protein subunits. The tubulin protein dimers of the microtubules have hydrophobic pockets which might contain delocalized π electrons. Tubulin has other smaller non-polar regions, for example 8 tryptophans per tubulin, which contain π electron-rich indole rings distributed throughout tubulin with separations of roughly 2 nm. Hameroff claims that this is close enough for the tubulin π electrons to become quantum entangled.[25] Quantum entanglement is a state in which quantum particles can alter one another's quantum-mechanical state instantaneously and at a distance, in a way which would not be possible if they were macroscopic objects obeying the laws of classical physics.
In the case of the electrons in the tubulin subunits of the microtubules, Hameroff has proposed that large numbers of these electrons can become involved in a state known as a Bose-Einstein condensate. These occur when large numbers of quantum particles become locked in phase and exist as a single quantum object. These are quantum features at a macroscopic scale, and Hameroff suggests that through a feature of this kind, quantum activity, which is usually at a very tiny scale, could be boosted to be a large scale influence in the brain.
Hameroff has proposed that condensates in microtubules in one neuron can link with microtubule condensates in other neurons and glial cells via gap junctions.[26][27] In addition to the synaptic connections between brain cells, gap junctions are a different category of connections, where the gap between the cells is sufficiently small for quantum objects to cross it by means of a process known as quantum tunneling. Hameroff proposes that this tunneling allows a quantum object, such as the Bose-Einstein condensates mentioned above, to cross into other neurons, and thus extend across a large area of the brain as a single quantum object.
He further postulates that the action of this large-scale quantum feature is the source of the gamma synchronization observed in the brain, and sometimes viewed as a neural correlate of consciousness.[28] In support of the much more limited theory that gap junctions are related to the gamma oscillation, Hameroff quotes a number of studies from recent years.[29]
Minerva
2,116
13
It's a thick layer of rubber that makes your feet more comfortable when walking around.
Minerva
2,116
13
Yeah I'd rather watch re-runs of I dream of genie instead. I do like the music though, it was before my time.
Rudee
11,218
The Soul is like the Easter Bunny and the Tooth Fairy. It doesn't exist. Santa Claus, However, is real dammit!!
szechuanpork
455
because immaterial substances are not things one can measure or quantify.
Jeff7
41,596
19
How come these type of magnets are almost universally sold unmounted. It's a recipe for pain. At least they could tap a threaded mounting hole in it.
Don't know.
Don't care.
Do want.
I have a smaller magnet that's rated for about 85lbs pull. It's maybe 1x2x1/4". It's just ridiculously strong for something that size. It's also interesting to see firsthand how strong magnets interact with aluminum.
(There are neodymium magnets that have countersunk holes in them, though they're usually rather small.
These magnets are sintered, and quite brittle, so threading wouldn't hold up too well.)
Then it also would be unable to have any effect on us.
Nemesis 1
11,366
Merely an attempt to explain why we see things the way we see them. There is no "Soul", just some peoples(mostly from the distant past) inability to understand the concept of Consciousness.
Thats your opinion along with billions more and your entitled to it. But first things first the soul is flesh . We all carry a spirit within and I personnally know it to be fact . Can I prove it ? NO. Even if I could I wouldn't. That was The living words job . But Religion has pretty much destoyed those words while at the same time hiding the truth and the complete message. I would bet anything your stupid enough to believe when Alexanders library was burned you believe the scrolls were burned also . Thats so laughable that it Ironic. Have you never asked yourself why the swiss guard protects the pope. I bet you will say its because the swiss are neutral . They have been in the past. Cough ! This next war the swiss banks will be raped and plunder something that should have happened long ago.
Irony (from the Ancient Greek εἰρωνεία eirōneía, meaning dissimulation or feigned ignorance)[1] is a rhetorical device, literary technique, or situation in which there is a sharp incongruity or discordance that goes beyond the simple and evident intention of words or actions. There is presently no accepted method for textually indicating irony, though an irony (punctuation) mark has been proposed.
