What is the material with the highest melting point?
SlowSpyder
17,305
1,002
My wedding ring is made of tungsten. It's good to know that if I ever am dipped in lava atleast my ring will be ok.
smack Down
4,507
Originally posted by: MegaVovaN
Probably they do NOT use carbon in space shuttles because
a) ceramic is strong (carbon is not) and
b) temp is not high enough to melt ceramics
They don't use carbon because it burns.
Mark R
16
That's true, but on space craft you *need* to use materials that will melt or evaporate/burn off.
The heat is so intense, that you can't shield against it, you actually need to dump it - The space shuttle tiles vaporize during re-entry, forming a cushion of combustion gases that shield the underlying tiles from the heat of re-entry, while the gas carries the heat away from the tiles below.
jagec
24,442
Originally posted by: Itchrelief
Try looking up those nickel based alloys used in jet engine turbine blades? Or whatever they use to line industrial furnaces and such? I'm no materials engineer, but even if you had one available to ask questions to, he'd probably want to know what the heck you were trying to do with this material before he could give a useful answer.
Inconel, Vascomax, Hastelloy, and the other superalloys are usually designed for high-temperature creep and corrosion resistance, and/or chemical resistance, not melting point.
Without knowing what the boss intends, it's kind of hard to make suggestions, though.
lozina
11,711
8
Uh oh.. Lord of the Rings IV coming soon: we learn the ring was made of tungsten and was not destroyed!
More hairy hobbit feet coming to a theater near you!
Jun 27, 2005
19,216
Originally posted by: LittleEnglish
I want to know what this "side project" is that Tungsten won't cut it.
I think he plans to start an earthquake designed to trigger a volcanic eruption and cover the world in liquid hot mag-ma. *pinkie*
DAPUNISHER
32,357
33,263
I bent my wedding band lifting weights, so your band is good for other purposes too. And don't forget a titanium band saved Ed's life in the Abyss :p
Squisher
21,204
66
QFT
Chances are tungsten will cut everything you'll run into, however cutting tungsten isn't so easily accomplished.
alkemyst
83,769
19
Since material was mentioned and not element that does open up the arena more. Melting would have to be qualified as scientific melting or subliming...diamond would win the former and not be able to be melted outside of a extreme pressurized environment.
I don't know if you HAVE to be able to melt it to qualify for this question...that's why I said the sun originally.
Tungsten is a textbook answer if asked what elemental metal, and carbon if asked what element. I think there are some radioactive elements that melting points have not been able to be measured due to life probably.
SlowSpyder
17,305
1,002
It's also extremely good at opening beers when I can't find an opener. I read somewhere that tungsten is 8x harder then steel and 4x harder then titanium... not a scratch on it and I've opened quite a few beer bottles with my ring.
alkemyst
83,769
19
Depends on the tungsten ring..not all are created equally.
Fenixgoon
33,578
13,259
diamond is 3550, just a hair below tungsten. never heard of tantalum halfnium carbide.. pretty slick though, for such a high melting point.
edit: the reason why nickel super alloys are used in jet turbine blades is because of creep strength and fatigue abilities, as jagec mentioned. tungesten is also significantly more dense than nickel, as well as its alloys. so while a tungsten alloy or ceramic may have superior properties to the nickel super alloys, the extra mass (among any other property discrepancies) will significantly affect the turbine blades or other parts.
BrownTown
5,314
Also for those saying that carbon isn't used on the space shuttle, you fail, its what is used on the leading edges and nose.
