What is the difference between WD2500JB and WD2500PB?
porkbun
440
I see these drives on newegg. They are similarly priced, but I have no idea what the difference is between the two. Thanks.
SithSolo1
7,740
11
Just guessing based on no real knowledge really at all I think the JB is the 8MB cache and the PB is the *quiet* 8MB cache. DOn't quote me on any of this as I really don't know and refuse to accept responsiblity for anything that happens if your base your decision on my qwerky guess work. :Q ;)
SithSolo1
7,740
11
Originally posted by: LTC8K6
PB is a Fluid Drive Bearing, I believe.
Correct, the PB is quiet and the JB is not other than that I am fairly certian there is no difference. :D
yourdeardaniel
1,905
WD2500PB has Features: Fluid Dynamic Bearing (FDB) technology, Shock Guard.
MDE
13,199
If the prices are similar definately get the PB. The JBs tend to howl after a while.
Gagabiji
1,460
does liquid bearing last longer that ball bearing?
Viper96720
4,390
Fluid bearings are quiter since theirs fluid inside. Sometimes after awhile the grease in normal bearings wear out. Then you may get a whiny bearing. They should last longer since not much metal on metal.
