jakobkraft
512MB Rambus 184pin RIMM 800MHz ECC
What is ECC?
Also, 800MHz = PC-800, right?
What is ECC?
Originally posted by: Rotax
"Generally" ECC I think is used in server type environments more so, or where you need an extra level of stability. It does some kind of extra 'checking', I forget the exact name for the abreviation.. "Error Control..??" something or other.. I believe.
EDIT: Also, in Rambus terms I do believe that its considered PC-800 (goes buy the speed of the memory) instead of how DDR is rated.. (PC2700=333, PC3200=400, etc)
