what is the difference between asus p4t533 i850e and p4t533-c
babah
94
Asus P4T533-C Motherboard for intel Processors, Retail Specifications: Processor Socket 478 for FC-PGA2 Pentium® 4 1.4GHz to 2.2GHz+
Chipset: Intel 850E ICH2
FSB 533/400 MHz
Memory 4 x RAMBUS Sockets Max.2GB, RDRAMS PC1066/PC800 Compliant RIMM
Expansion Slots: 1 x AGP 4X 5 x PCI 2 USB
IDE Ports 2 x UltraDMA 100/66/33
Audio ac97 codec S/PDIF-in
Onboard LAN Intel® 82562ET PHY
Asus P4T533 i850E Motherboard for P4 Processors Retail
Specifications:
Supported CPU:Socket 478 for Intel® Pentium® 4
Chipset:Intel® 82850E MCH Intel® 82801 BA ICH2
FSB:533 / 400 MHz
RAM:2 x 232-pin 32-bit RIMM Sockets support max. 2GB PC800 RIMM3200 (800MHz) / RIMM4200 (1066MHz) ECC / non-ECC RAMBUS memory.
IDE:2 x UltraDMA 100 / 66 / 33
Slots:1 x AGP Pro (1.5V only) 6 x PCI
Ports:2xCOM,2xPS2,2xUSB, and Audio Ports
Onboard Audio, C-Media
So this is mean if i use asus p4t533 i850e i can use either pc1066 memory or rimm4200 memory...correct me if i wrong??
Thanks guys
GrumpyMan
5,780
265
I was under the impression that the P4T533 has to use 232 pin RIMM 4200 ram which is different than 178 pin Rdram. My pin count is probably wrong but near there.
zzzz
5,498
No you can only use RIMM 4200.
John
Moderator Emeritus<br>Elite Member
Actually as long as it is 32-bit RDRAM you may use it in the P4T533. If you want to use the older stuff get the "C" version.
