lavaheadache
Seems like there are a few reputable members that rely of frame limiters for smooth game play for various games using either Amd or Nvidia setups.
Thats right. My GTX 670's can easily get me there but my CPU just can't do it. Keep in mind that lowering graphics settings to medium or lower reduces the load on the CPU, so at that point a 60fps min is more likely. Ultra is a different story. But Ultra is what I play at and truth be told, the game runs great and is almost always at 60 or higher, but I still get those drops. The drops aren't brief either. They are persistent depending on where I am at on the map. If the whole map is in view from a rooftop, FPS goes to the 50s.
I believe you. You are also running at 5ghz, so this makes some sense. But even then, you have occasional drops to 50 as you mentioned. Isn't that a little crazy given your specs and OC?
Funny too cause some games like UT2004 are awesome at like 200fps but lol god behold if BF3 doesn't have a cap enabled to stay under 70fps lol,my last post about the testing with the x4 9150e gave me a conclusion as well.
Seems pc gaming is becoming assbackwards where stutter and lag is only fixed with vsync or a cap enabled,and a few years ago it was the whole other way around.🙄
Coming back to the point, to people who say BF3 MP dips below 60 FPS.
Have you played these games with MSAA = 4x and MAX settings?
Sleeping Dogs
Hitman Absolution
Farcry 3
Crysis
Crysis 2
Metro
Need for Speed Most Wanted
There are probably other games like the above as well, including Alan Wake and MP3 but those two only throttle single GPUs.
Anyway, I doubt in any of the above games you get constant 60 FPS if you turn MSAA to 4x.
Anybody who has an experience which states otherwise?
If so, details please?
Sleeping Dogs
Hitman Absolution
Farcry 3
Crysis
Crysis 2
Metro
Even if I assume that we do get a 50% performance hit with MP, all I have to do is play at 1080p ultra and switch off MSAA/FXAA in BF3 MP to maintain 60 FPS.
Can I play NFS at 1080p Max but no AA with 60 FPS minimum? NO
Can I play Metro 2033 like that? NO
Can I play Crysis 1 with 60 FPS average? NO
And I am 100% sure that there are a lot of other such games perhaps on the lines of Planetside etc as well, which won't run okay even with out MSAA.
The only thing I need to do is drop MSAA with BF3 and I am all set. With the above games they still won't be playable.
I really don't get it when people say that BF3 is taxing. Really, it is far from that.
Of course I have only played the Single Player but I have finished it and it is one of the lightest games on my PC that I have played in recent times including Sleeping Dogs, Absolution, Farcry3, Crysis1 without mods, Crysis 2 without mods, NFS etc. all these games are far more intensive that BF3 SP.
These are the kind of FPS I used to get in BF3 SP with the setup below:
2600k 4.3
16gb ram ddr3 1866+
7970 at 1125 1575
Cat 12.4 or something. Way before recent drivers came out.
1080p 4x AA, everything max
Avg fps 80-100+ maybe higher I don't remember exactly
Min FPS mostly 70-80+ with rarely below 70 fps
1440p max but no Fxaa no msaa
Avg fps 70-90+
Min fps usually around 60-70 or so and very rarely below 60 if at all
And the other games I mentioned don't run this well with my rig, not even Crysis2 which is the lightest of the lot.
I really don't get it why people think it is intensive. There are dozens of games more intensive that this including Shogun, Metro, above list etc.
Of course MP is more intensive but I still don't see it being as intensive as some of the more intensive games I have played.
As for BC2 you rarely go below 50-70 fps even at 1440p 4x msaa and max. And avg is more like 80-120 fps or so.
I installed MP and as expected, I was right.
BF3 MP
A random 64 player map:
1080p Ultra no AA : avg fps 90-120, min 70-90 fps
1440p Ultra no AA : avg fps 80-100. Min fps 70+
1080p Ultra 4x MSAA : same as above
Caspian border:
1080p Ultra 4x MSAA: Avg 60+ with occasional dips to 50s. Again, very playable.
Now if I just remove MSAA or even use 2x MSAA then I will easily get 60+ fps minimum 99.9% of the time including fights.
My experience with BF3 MP is exactly the same as with SP. there is no difference in fps. And I have tried 2 different 64 player maps. There may be a 10-15% performance hit or something but nothing extreme.
I rest my case.
People never claimed that single player was taxing. At least thats not what I remember reading. Single player will run on a core 2 duo. If you want to see what everyone is talking about, go to a 64 player Gulf of Oman match and report back with your FPS.
Why keep asserting a set of facts that has been empirically proven wrong by several members?
You could give the 64 player maps a try yourself.
Because people make a big deal about how intensive bf3 is when it isn't. There are lots of games which perform far worse and several of them are in fact CPU limited as well.
Bf3 is just another average game from a performance perspective. It is no Crysis. It is just another game which everybody with a mid range system can max without AA and with a regular high end single gpu setup with AA.
Vegetation areas: avg 60-75 or so. Occasional 50s. Momentary 40s for a split second. Nearly impossible to notice 40s. Practically 50+ throughout and mostly near 60ish or above. 100% playable. No need to reduce the settings.
