imported_Kensai
- Nov 11, 2004
- 10,855
- 0
- 0
Originally posted by: Coolin
Originally posted by: Jeff7181
To be honest, I'd just make it one big partition. Or divide it into two equal parts. I used to like partitioning large drives... I even had my Raptor partitioned. But I find myself estimating the wrong sizes and end up with a partition for applications that's too big... or a partition for the OS, applications, and swap file that's too small... or a partition for data that's too small... etc. I don't think it makes much difference performance wise anymore... just reduces the time it takes to defragment your boot partition if it's smaller.
The problem with this method is that if you reformat, you lose all your MP3s/videos etc... Or you'll have to burn them all or something problematic like that.
Originally posted by: Sforsyth
Damn still semms confufing to me, ok I will have an extra 10 GB HD laying around do you think I should use this as well or no ? maybe make it for a swap file or something ?
Originally posted by: SectorZero
My suggestion:
- 30 gig for OS and Apps
- 1 gig for swap file
- The rest for Data
Note: I would also recommend pointing your My Documents folder to the Data Partition.
Originally posted by: DLeRium
10 GB for XP. you can install office and some critical apps here.
And for what's left...
HALF for games/apps: some games/apps will run even after you reformat, so don't lose those game files. Plus, if you're lazy like me you don't have to reinstall some cheap apps
HALF for music/movies/files/whatever you need it for
My suggestion:
- The rest for Data
Originally posted by: Sqube
Multiple drives > Multiple partitions
Get a little one for your OS and your swap(?), use the 250 to store everything else.
Originally posted by: AnitaPeterson
I'm interested in doing this myself....
If Windows is already installed, is Partition Magic (currently at version 9, and a Symantec product) the best application for this job?
exactly !!!!!!
and btw, just in case you (OP) dont know what multiple partitions means..
Multiple drives > Multiple partitions > More overhead
