What is the best rechargeable battery for digital cameras?
Solodays
853
Are you all digital camera owners use rechargeable batteries? Mine uses 4 AA's and doesnt last very long, howcome they consume some much power? This is unbelievable.
Ryan
27,519
I just have some duracel ones I bought from Walmart - works perfectly :)
Nebor
29,582
12
Monster brand rechargables are the best. The double AAs I use in my digital camera were like $19.99 each, and I had to get 4, but they really made the picture a lot sharper!
habib89
3,599
how does batteries make a picture sharper? interesting..
just get like 3 sets of rechargables.. should give you a lot of shots if you go on a trip or something.. then you can recharge them all in a few hours if you get a 1 hour charger.. under 1 hour if you get a 15 min enegerzier charger.. rayovac 1hr chargers are fairly cheap.. some batteries and a charger for like 20ish bucks.. a 4 pack of AA's cost about 13-14 at frys
Kelvrick
18,422
Don't forget the monster usb cable from the camera. The transfer speed was twice as fast as the memory's theoretical read speed!
Nebor
29,582
12
I got the one with platinum spinner connections. It's bling-transferrific!
jadinolf
20,952
:confused:
spacejamz
10,993
1,737
What about the Monster lens cleaning cloth? That makes the media go faster as well...
Best 49.99 I have spent in awhile...
spacejamz
10,993
1,737
Seriously, one of the things to look for in a camera before you buy it is the battery type...
Ones using lithium ion batteries will hold their charges longer...anything using AA or AAA batteries won't last nearly as long...on the flip side, if you are running low on batteries, you can duck into most any store and pickup some new ones right then and there...
my two cents...
RKS
Originally posted by: axelfox
powerex nimh with powerex charger at thomas distributing.
they get my vote
2 sets of these batteries and a charger and you are set
BullsOnParade
1,259
Powerex's by Maha are very good batteries, however Energizer's NiMH batteries generally top the list. You
might want to make sure which type of Energizers these are, they may not be the same ones as the fast charge
or ones you find at Costco.. or they could be I haven't checked in a while. And I'll second Thomas-distributing, great
site.
Solodays
853
I'm trying to find the Energizer NiMH rechargeable batteries 2500 mah with a rechargeable, but couldn't find it over amazon.com
Ornery
17
Originally posted by: FrustratedUser
Batteryspace.com
2300mAh + cheap = awesome
Good call! :thumbsup:
Just ordered 24 Pack AA 2300mAh with free shipping this morning.
Use coupon code: batteryspace for 5% extra discount
Many great Battery/Charger Combo Deals if you also need the charger.
Pffftt. Bang for the buck factor: Negative ten! :thumbsdown:
Pabster
16,986
Maha gets my vote. Love the chargers and the batteries.
Besides that, Energizer that you purchase at your local Wally World are decent too.
Stick to 2200mAh or above.
Sphexi
7,280
You're most likely using straight Alks, which have a totally different power curve from Lithiums or rechargeables (Ni-MH). Over time as the amount of their charge goes down, alks lose their voltage as well, at 50% of their charge left they generally put out about 1.35v or so rather than the 1.5v they're rated at. Digital cameras especially are very picky about the voltage they'll run off, so once the batteries die down enough they simply stop working, even though you could pop them into a cassette walkman and they'd work great.
Stick to Lithiums or Ni-MH, my A95 gets over 300-350 shots per set of Lithiums, haven't tested it with rechargeables yet but I will soon.
ElFenix
102,407
8,592
turn off the flash and the LCD screen and you'll save a lot of power
Ornery
17
OMFG! You actually pay over $8.00 for batteries for 350 pictures? :shocked:
aceO07
4,491
Try Sanyo NIMH rechargable batteries. I'm not sure what their capacity is at now, but it should be over 2400mah.
