also want to know, what is a good inexpensive p4 that overclocks well...I have built nothing but amd rigs and want to learn about intel chipsets and p4s
is all P4's sticking with the 478pin config? Cause the Xeons seem to have moved up to 603pin/604pin. Is it a requirement to move to new speed territory a new socket needs to be in place? For intel, history seems to indicate that to be the case. If so, what's the lifespan of the current 478pin socket?
400FSB may give you slightly better hopes of overclocking.. 533 may push your FSB or memory speeds too high depending on your RAM and such.
400FSB CPU's are a safer way to O/C, it's more reasonable speeds (for memory and bus speeds)
533 is faster out of the box, and will overclock, but you can VERY easily get 533 FSB from a 1.8A for example. mine was well over 600.. don't know off hand what exactly it ended up at.. somewhere around 620 FSB...
Originally posted by: Chunkee
does it matter what the cache size is on the processor? What about the FSB...is 400 better than the 533? IS socket 478 better
P4-1.6A SL668 MALAY, L150A422-0282, w/o HSF, Overclocks to 2.4Ghz @ 1.55V rock stable
Well, that's says pretty much everything about his cpu.
It was able to do that with ASUS P4B266 mobo I currently have for sale.
Any other specific questions? ask me
I bought both a P4b533E Raid board and a p4 1.6a processor used on the for sale board and picked up a 256 mb stick of corsair cas2 ram from googlegear and have clocked my processor up to 2.56 ghz currently @ 160 FSB. Thats a 60 FSB increase over stock with memory running at 3:4 ratio, i am very near rambus speed rates. I am using a pny geforce 4 ti4200 card clocked at 300/600 and my 3dmark 2001 se scores jumped almost 4000 points from an normal 1.6a stock speed with stock video card settings.
Very, Very impressed with these scores and how fluid my games are!!
