- Aug 23, 2003
- 25,375
- 142
- 116
Turning someone's brain into a wall decoration is pretty deadly.Originally posted by: SunnyD
Anyway - just curious why bullets are so deadly.
At least it is in COD4; never tried it in real life.
Originally posted by: MrLee
Originally posted by: daveymark
Large bullets, and small bullets that travel very fast, such as those from an M-16 rifle, can kill almost instantly, mainly by reducing the region of impact literally to hamburger. They also generate something known as "hydrostatic shock." The body is composed largely of water and as such may be viewed as a hydraulic system. Liquid being noncompressible, the shock caused by the high-velocity entry of a large projectile (don't you love this technobabble?) is transmitted throughout the body, causing widespread organ damage and disruption of nervous functions. Even a wound to an arm or leg can be fatal in some instances.
See, THIS is what I'm asking. INSTANT death, as in do not pass go, go directly to the pearly gates...
I know that internal damage to a severe enough level will cause death, and bleeding will cause death - but I'm talking about the people that drop as soon as their hit. Bye bye. Dead.
Bleeding out, well I suppose if something major is hit and you're bleeding out profusely, your blood pressure nosedives and you basically expire. But still, bleeding out should give you a few seconds to gasp your last.
My guess is that movies and videogames play up the instant death aspect. In reality (I think), people don't die right away from gunshots. Often the pain and shock associated with taking a bullet will drop somebody right away, but they'll still be alive on the ground.
I think the true stopping power has been debated for quite some time. Probably on this forum even. A drop to the ground, instannt dead sort of an instance will only occur of the mere shock of the event makes the victim pass out or if there is nerve damage from the bullet penetration.
Stopping power in itself, the stuff that takes someone to the ground immediately, can only be found with a higher caliber hand gun. In all reality, nothing is truely stopping someone from being shot and then continuing on with their actions. In severe incidents, a victim might have enough adreneline pumping throught them that they may not even care enough to stop whatever they are doing.
The stuff that makes them drop all the time? Movies.
Originally posted by: vi edit
You'd be amazed at what *doesn't* kill you instantly.
My wife has worked some trauma rounds where people have be wheeled into the ED with half their face missing, holes in their head, gutshots with shotguns, ect from failed(at least immediately) suicide attempts and gang shootings.
Most of these are from handguns and less devistating rounds than you would see from high caliber rifles though.
Yeah my old roommate was an EMT, and has seen even suicide attempts where a large part of the cranium and sinus area was missing. Yet the 'victim' survived.
The ONLY time you can reasonably expect "instant" death from a bullet is if you hit the person in the head or in the cervical vertebrae (the vertebrae in the neck) and sever the spinal cord, and even then it's not guaranteed.
ZV
Originally posted by: purbeast0
i call shens on you holding a soldering iron for 10 seconds ...
You don't die that quickly unless you're shot in the brain and maybe the heart. What you see in the movies or TV, especially the older stuff where the person just drops to the floor/ground is just a euphemism.Originally posted by: SunnyD
Originally posted by: miniMUNCH
blood loss... unless it is hits you in the head and/or heart.
Shock is different for different folks... I have broken bones, etc. in the past and never once went into shock even though the pain was extremely intense.
Pretty easy to do....take out your frontal lobe(s), or most brain above the brain stem, and that doesn't guarantee death at all. Blow out your brain stem and you're dead.....no matter what.
Good, we'll tell the army to immediately recall all rifles and start issuing Desert Eagles.
P)
Originally posted by: gamepad
OP: Pics of scar on your hand to prove it
