- Oct 18, 2004
- 3,432
- 3
- 81
Not a hub assembly with the bearing included. But just the hub itself.
I think i have a bad hub because i had a front wheel wobble. I replaced the wheel bearing only and its still there. The only part that is moving is the axle. Which leads me to believe only 3 items can be bad, CV axle, wheel hub or wheel bearing. Axle nut was tight, just had to make sure of that. CV axle was replaced last year, wheel bearing was just done, i guess i should of done the hub as well. So before assuming one of the newer parts are bad i'm trying to see if the last old part is part.
What is in a hub? Could it cause my wheel to have play. Is there a bearing in there as well? I know it has the studs and a seal but what makes it able to spin freely?
Is there a way to test JUST the hub?
Everything i google/youtube is people mistaking wheel hub as wheel bearings/ assembly.
Can i just pull the hub off with a slide hammer? Or do i need to make another trip to have the hub pressed in.
