boomerang
I doubt you've stripped the threads. What exactly happened I can't say but the seat for the plug is no longer concentric with the threads. The seat can be recut with a tool. The tool threads into the plug hole and there is a cutter that will recut the seat. There will be aluminum chips as a result that you really don't want to go into the cylinder which is why way, way, back I suggested you take it somewhere and have it done.
It is also possible to cut the seat too deep and that will allow the end of the spark plug to project too far out of the cylinder head and then you could have an interference problem that could damage the plug. Also, if a thread of the plug is exposed into the combustion chamber it could get hot and cause pre-ignition.
I don't want to bring you down but if the seat is too messed up, it may require more expensive repairs.
Please, don't think I'm talking down to you when I say this. Have this done by a shop with the tools to do it. We all have our limitations and knowing them can save us time and grief in the long run. This is a task you should farm out.
