AzN
Banned
- Nov 26, 2001
- 4,112
- 2
- 0
Originally posted by: dclive
http://www.tomshardware.com/re...e-gtx-275,2266-14.html is another interesting post from Tom's Hardware. Basically it shows those (fully modern) GPUs all would be fine in a system with a PSU of 300W or so, call it 350W for lots of excess capacity. The 4870x2 would need about 500W.
That's it. And that's for an i7/965 setup with all power saving disabled. That's a fully modern, fully current system.
This doesn't tell much. Just says AC power usage. Nor did they test a modern system with a 300 or 350 watt power supply instead they tested with 1100 watt power supply with plenty of amps. Just because a power supply is rated at such doesn't mean it can run a modern full fledged system with it.
Now if you show me a 300/350 watt power supply showing results and extensive testing to random reboots and stability I would believe it.
