what is a subwoofer??
OIKOS
Banned
Mar 29, 2000
1,669
uuh... anybody know what is a subwoofer?? my friends were talking about it, and i didnt know what the $@%#&......
and what is Hz?? like 25Hz , 50Hz........ i am soo confused... my friends were laughing at me.... :(
thanks..
Turkish
15,547
thanks..
it's a tool of moronification.
Dragon365
1,238
<- Not an audio expert, but i'll try anyways
Think of it as a big speaker which spits out low frequency sounds, 20 hz being the lowest frequency that the human ear can detect, so the lower the hz that a subwoofer can deal with, the better.
psianime
1,497
You make waffles with it. Sometimes you can make pancakes too but thats only the deluxe model.
Seriously, if you want to know what a subwoofer is you should do a search on google. Subwoofers is related to bass amplafication.
Deeko
30,213
12
wow...I learned that when I was like, 5....
anyway, a sub is a big speaker dedicated to bass. If you feel a lot of bass coming from someone's trunk, that's a subwoofer. If you see a big single speaker sitting on the floor of a home theater system, thats a subwoofer. Hz is the audio level, lower hz sounds deeper.
PeeluckyDuckee
4,464
Somebody might still be trying to find the right way home cause you nabbed that detour sign :p They're prolly in Rio De Janiro by now :)
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
I can see why your friends laughted at you.... If you just broke down the word, it wouldn't take too much to figure it out. The parts of the word aren't even in Latin or Greek, like most words in English. Anyway:
subwoofer
sub : below, as in below the surface of the ocean
woofer: something that barks
a subwoofer is the guard dog at naval stations. They started using them as an early detection system for foreign subs, torpedos, etc.
pennylane
6,077
I'll mention it since nobody else has. You figured out what a subwoofer is right?
Frequency is one way to measure a soundwave. The unit of frequency is the hertz. Which means.. one cycle per second. Sound travels in waves, so one "cycle" is the distance between the the "peaks" of a soundwave (as in peaks on a sine curve. you know how it goes up and down...)
High frequencies (in the kilohertz) correspond with high pitches and treble.
Low frequencies (like 20 Hz, Hz is a hertz) correspond with low pitches and bass.
Speakers can handle treble and mids pretty well alone. But they can't generate low frequencies as well. So that's why there's the subwoofer.
Harvey
Administrator<br>Elite Member
73
OIKOS -- A subwoofer is a speaker designed to reproduce very low frequencies. Speakers generally fall into one of several catagories:
A tweeter reproduces very high frequencies. A midrange speaker obviously is used to reproduce the mid range, and a woofer is used for low frequencies. There are also full range speakers that attempt cover the entire audio spectrum.
Most common speaker systems are two or three way designs with one or more drivers used in each range, but reproducing bass requires substantial mass, so some smaller speaker designs do put out enough bass. This is OK in a small apartment, but if you want to fill a large space with kickass bass, a subwoofer with a separate amplifier is one way to do it.
The good news is that low frequencies are pretty non-directional, so a single subwoofer can be used to reproduce the low bass range for the combined left and right channels. In fact, if you understand the physics of sound reproduction, you'd know that separated subwoofers would probably cause more problems than they would fix, but that's another subject.
I'm glad a couple of other guys had the courtesy to give OIKOS a straight answer, among the jokers. :p
