theonlymantis
Hello,
I have a problem... Norton keeps telling me that I damaged a partition (or partitions) on drive C. It says only a low-level format can fix this problem. What is a low-level format, and how do I do it? Will it destroy everything, like a regular format? I am running Windows 98 second edition. I should note that I just partitioned my hard drive to install Linux (successfully, but it took a week) on another partition. The comp seems to work fine, but it says "If you cannot access these partitions only a low-level format can fix these problems" (or something very close).
Should I reformat? Will I need to reinstall everything? And second of all, if I do reinstall, should I go with windows 2k instead of 98? I have access to it, just wondering if I should bother.
Thanks alot, I appreciate your help!!
Goldie
Goldie
