Originally posted by: glen
So, can i get an electric and just plug it into an ipod rather than an amp?
Originally posted by: RaDragon
I started playing on a classical guitar with nylon strings. They still hurt my fingers, but not as much as the strings on an acoustic/electric.
Sounds like a poorly adjusted guitar bridge. You fingers should not "hurt" when playing electric if you are playing properly. One of the best things about electric guitar is that you don't have to have to put pressure on the strings as you do with an acoustic guitar when you fret a note or chord. If the pickups and bridge are properly adjusted, playing the electric guitar should be a very pleasurable experience with little to know finger discomfort.
acoustic (whether it has pickups or not) and electric guitars are different animals with a different feel. The pickups on the acoustic will not give you the distorted sounds you're expecting out of an electric guitar, so it's not really a best of both worlds situation. If you go acoustic, as a beginner I wouldn't waste my money on a model with pickups, you're not going to plugging into PA's and playing for anybody.Originally posted by: glen
Well, wouldn't the ideal be to get an acoustic with pickups, like an Ovation 1863 so it can be plugged in also?
So, which model Ovations start getting to be decent?
Interesting -- it was probably as you mentioned although it wasn't my electric guitar, so I dunno what his settings were.
Seconded.Originally posted by: Yanagi
I disagree. Acoustic guitars are much better to start practise on. Granted not as fun as playing electric but you train your fingers much faster with an acoustic. Then it takes some time to get used to the narrower neck of an electric but your fingers will be up there at least. For a beginners Electric guitar I wouild recommend either Epiphone or Washburn entry level guitars. I have one of each and while the washburn is easier to play on the Epiphone has better pickups. I have a pic of both of my babies. They are niice 😀
Pay no attention to the Ovation haters. I've never seen one with problems with the wood/plastic. I know a dude that bought one of their cheaper Applause guitars in the early 80s, and the only reason he can't play it now is because one of his friend's kids decided to jump on it (and it's still in decent shape considering). There's nothing wrong with them, I've played a number of them at guitar stores in addition to the one I own (which has a nasty crack near the headstock, but still plays well for it).
I would suggest going to local guitar shops and just trying some various guitars out and see how they feel/sound.
I have one too 🙂 The only real problem with them is the metal neck tends to warp and it's not easy to adjust because, well...it's metal! I still have my first Ovation Matrix from 1982!
