Why not just run the drives in RAID1?
Raid is not backup, unless you meant two drives in raid 1 but still have the offsite... then yeah that could work given the backup drive is in the same machine anyway.
Tapes? There's a reason you haven't heard much about tape drives in the last 5 years.
Check out tape drives at newegg... you'll see it's much cheaper to use HDDs. It's also faster, easier, and more convenient.
As pros and cons go, HDDs are all pros, no cons vs. a small home tape solution. I suppose one pro for tapes is if your tape is too small, then you can get another tape for cheaper than another hard drive, but if you only need 500 GB, then buy a 3TB hard drive "just in case" instead of a tape drive, you're still WAY ahead on cost by using the HDD.
Yep, I had looked into tapes when I was researching for a backup solution. I saw the price of tapes, about 60 bucks a pop, and was kinda turned off, but figured maybe it's not that bad since drives are 100-200 bucks. Then I saw the price of the drives. 10k for very entry level drive that fits in a cdrom bay. Yeah, hard drives are cheaper.
