xthetenth
For productivity, I prefer the narrower aspect ratios as it brings my side monitors closer in, and the side monitors themselves can be smaller. As an example, at work my 19" 1280x1024 is almost the same vertical height and PPI as my 24" 1080p display but is only 66% of the width. I can get 19+24+19 on my desk, but couldn't with 16:9s. Since the side ones are usually used for email, PDFs, etc, there's no real reason to have all that extra horizontal space.
That can work, but I find that's one place where a 21:9 really shines as a replacement to the whole of a setup like that. It's not half again as wide as a 2560x1440, but it gives two good sized windows side by side, and if you just narrow windows down to their content, three or four columns are easily possible. I've got an RDP window 3440x1440 open right now with four columns, two code in the middle, a set of terminal windows on the left and a narrow directory hierarchy view on the right. Trying to fit that sort of arrangement on a pair of 2560x1440s is a royal pain, because rather than the edges being 1720 pixels away from the middle and having 3440 pixels, on a pair of 2560x1440 a similarly wide screen area is 1280 pixels away on one side, and 2160 pixels plus two bezel widths away on the other. The near half of that second screen is far enough from the middle to be annoying to use, let alone the far half. I can also pop that window onto two thirds of the screen and have most of the use of that as well as being able to easily use my own system.
