What Happened In Yosemite?
skyking
22,829
6,001
CO is lighter than air and CO2 heavier. You would have to be in an inclosed space to be be CO poisoned or inclosed or at the bottom of a depression to be poisoned byCO2 seems to me. Don’t know where the bodies were found but if out in the open either gas doesn’t make sense to me. What in Yosemite would be a killing source of either that could get you while hiking.
the difference in molecular weight of CO to air is minimal and it readily mixes with air and does not disperse upward. I deal with this in my line of work. My experience with automobile fumes laden with CO is that they do tend to settle. I work in confined spaces from time to time, and I have been chased up out of a structure in the ground that has filled up with CO and set off my alarm.
it is more readily detected in autopsies, however. That is what is puzzling about this case. If they died of CO poisoning it would be found in the blood and tissues. Simple hypoxia is not easy to detect.
Reactions: Leeea
MtnMan
9,445
8,853
Could it be methane gas?
Methane and CO are lighter than air, thus would disparate upward.
CO2 is heaver than air in will collect near the ground.
With the ambient heat at Yosemite, I tend to think methane would just autoignite.
Uh NO!
Spontaneous ignition temperatures for stoichiometric methane-air mixtures are around 870 K (600°C/1112°F) at atmospheric pressure and decrease to 660 K (390°C) at 1100 bar ignition pressure.
But yes, the expert weighs in with "I tend to think". Do they not teach some fucking basic science in school anymore?
skyking
22,829
6,001
CO does not separate out and rise though. It just mixes in and hangs around. Still, any autopsy would find evidence of CO, so I am skeptical of that.
Reactions: Pohemi and Leeea
Nov 17, 2019
13,420
7,904
^^ When I installed a standby generator, I read op on CO a bit as far as distance to vents. The gist of it was that CO is relatively the same weight as ambient air and drifts easily at any level.
But it has to be concentrated to have any effect and I can't see that in an open air setting like a hiking trail. Same with CO2.
If this was a gas, it would have to have been a concentrated cloud. I haven't seen enough to know if they were in a hollow or valley of some sort.
And there would be other animal casualties.
I'm not sure if they've tested for poisons that might have been deliberately administered.
Reactions: H T C and Leeea
Leeea
3,799
5,566
I have spent a small amount of time in the Yosemite.
This sort of thing seems so remote out there. More then a bit disturbing.
Amol S.
2,587
783
Uh NO!
Methane comes from the ground or may also contact lava. This could raise the temprature of the methane to surface ignition point. When reaching the surface, it could ignite. Another possibility is, one of the hikers may have lit a lighter for a cig.
Reactions: Pohemi
skyking
22,829
6,001
150~200 PPM will kill you. That is not what I would characterize as concentrated.
https://www.cpsc.gov/Safety-Educati...-Center/Carbon-Monoxide-Questions-and-Answers
Reactions: Pohemi
MtnMan
9,445
8,853
I don't recall any mention of they were "burned/charred". Got a link that says they suffered burns, or even resulting wildfires given how extremely dry it is out there?
Super heated methane when exposed to oxygen would be like a giant blowtorch coming from a vent.
Reactions: Pohemi
skyking
22,829
6,001
It is a mystery for sure. CO leaves a trace in the body, so does h2s, and methane. They will all be found.
The few gasses that don't leave an autopsy trace are CO2 and nitrogen. That is why the go bag for death with dignity is a source of nitrogen and a bag. A couple of breaths of nitrogen only and you pass out and die, and since it is 70% + of the atmosphere there is no lingering trace of it.
I daydreamed up a go bag deployment that involved a helium balloon and a nitrogen cartridge and bag.
Kick back on the lounge chair, off yourself with the nitrogen, and then a timer releases the bag from around your neck and the helium balloon carries all the evidence away.
"Hmm, he died in his sleep in his lounge chair, that lucky bastard!"
Sounds bad? Try on dementia or cancer or any other lingering death. Yeah no thanks.
MtnMan
9,445
8,853
The toxicity of CO is that it is absorbed through the lungs into red blood cells. That red blood cell is no longer capable of delivering oxygen to organs in the body. If a person takes a single deep breath of only CO, they are dead, unless their blood is replaced immediately.
With CO2, helium, argon, etc., a deep breath of that gas, may make some light-headed, dizzy, or even pass out, but the next breath containing oxygen will continue to supply O2 to the organs, and brain. Example: ever inhale a helium balloon to alter your voice, and get a bit light-headed?
MtnMan
9,445
8,853
The problem with CO is that is bonds with red blood cells, virtually taking them out of the function of delivering oxygen to your cells. Low concentration will fucking kill you, because each breath takes more and more red blood cells out of the game.
Do we know they are not animal casualties, snakes, rodents, even insects, etc. in their burrows or dens?
balloonshark
7,274
3,700
I'm going to guess they happened upon two talking bears and one of those bears stole their pic-a-nic basket. Without food and water the family ended up getting dehydrated and dying.
Indus
16,601
11,410
Could also be cyanide but what in Yosemite would produce it?
I've seen people overcome by cyanide in sewers by the smell of feces and die but out in the open is really perplexing.
Moonbeam
74,905
6,788
The point I was wondering about is that I can think of no way that poisoning by either gas could reach toxic levels while hiking in Yosemite park. CO can kill you in a tent, however, more so at altitude.@
[DHT]Osiris
17,512
16,838
Presuming the dog was hanging out with them in the tent.
My bet's on a new strain of brain-eating amoeba. Gaia fighting back.
Torn Mind
12,086
2,774
Much gnashing of teeth has now occurred amongst bureaucrats as the federal government loses tourist money due to bad press.
Uhtrinity
2,263
202
I love it when people say CO2 is non harmful. Yea, try breathing pure Argon. It's noble, doesn't react to hardly anything, it's not toxic. If you crowd out oxygen, it just doesn't matter. My years in the shipyard, probably in my 39 years, there were several suffocation deaths due to argon in tanks.
Back in the late 90's I used to play paintball. One time I left a C02 tank in my truck not thinking much of it. On a hot summer day I got in the cab and closed the door. Before I could start the truck I realized I couldn't breath, quickly opened the door and got out. The burst disk in the tank had burst releasing the CO2 into the cab. Luckily I got out before passing out.
Zorba
15,613
11,256
There's the algae thing, but wouldn't that mean they all had to consume water from the same source at more or less the same time? Or can algae put out a gas?
I know blue green algae can put off s toxic gas, but I've just heard of it making you sick.
Zorba
15,613
11,256
Even liquid nitrogen can be very dangerous, because if you have a large leak it can displace the oxygen in the room. Doesn't make that 79% of every breath is already Nitrogen, without the O2 you die quickly.
Zorba
15,613
11,256
This is ridiculous numerous people die every year in Yosemite. The week before I climbed Half Dome 5 people died on the trail, and the trail was still packed when I did it.
People have gotten sick (and I think died) from rat shit in the tent cabins, good luck reserving one less than a year out, though.
