what fire starting tools do u use backpacking?
jiggyest
103
hrm... my canister stove comes with a firestarter.
For back-up I have a magnesium firestarter stick. I also carry a pack of waterproof matches. Overkill, I know.
mizzou
9,734
54
Just ordered a magnesium strike starer for $5 will do some expirementing this weekend :)
spidey07
65,469
The dryer lint makes it easy, just toss a spark onto it and you're good. Otherwise you make a small pile of Mg and throw the spark onto that.
In wet weather I'd imagine it would be pretty difficult to find suitable tender.
zinfamous
111,857
31,346
spidey07
65,469
A little googling and youtube has me interested in the "blast match". I'm liking the one hand operation.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Generally, just a cheap disposable lighter; and I always take two. Most of the time that I go backpack camping, I take a small propane bottle that I use for a little one mantle light that's smaller than my fist & only weighs a couple ounces. Since I take the tank, I'll often toss in a light blowtorch fitting. If the lighter won't start a fire, the blow torch will.
sao123
12,653
205
generally speaking, when we go camping, we take a set of acetylene torches, they start fires pretty quick.
if im going portable, ill take the propane torch.
duragezic
11,234
4
See http://www.youtube.com/user/nutnfancy and search for "firemaking" or "backpacking" videos. He's real intense about bringing multiple ways to start, and for harsh cold/wet weather, yeah I can see that. But for a sunny day or how I'd go I'd just use a Bic lighter.
You can tell nutnfancy doesn't smoke cause he brings some piece of shit lighter that lasts 1/10 as long as a Bic if it doesn't break in a few days.
Leros
21,867
7
Usually just a lighter and some dry grass.
I've gotten desperate before when the firewood was damp and doused it with gas first. (The stupid park did not allow you to bring your own wood, which meant you had to buy theirs, but their wood was damp. I couldn't start it without gasoline).
spidey07
65,469
I see what you did there. Not biting.
Fayd
7,970
www.manwhoring.com
btw, for the OP: zippos and butane lighters are advertized as "windproof". i'd believe it on the butane lighters. i have a zippo knockoff, and you have to refill them often. often enough that i wouldn't consider it for backpacking.
mizzou
9,734
54
Yeah, zippos pretty much arent reliable due to the evaporation problem. But damn if it isnt the sexiest way to light somethig up
lxskllr
60,043
10,532
Genuine Zippos are extremely reliable. You can't store them fueled long term, but they'll last a week camping. For extra insurance, a tin of fuel doesn't take much room or weight. You can use a Zippo for quick emergency light, as well as making fires. They can't be submerged like butane can, but that's why yu carry a butane backup ;^)
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Zin's the only one to mention steel wool (sorta) but, it's a good thing to have to accompany your Bic or waterproof matches. It burns hot and doesn't matter if it's wet. I've used it successfully to start damp fuel when it was wet out.
zinfamous
111,857
31,346
thanks. finally someone acknowledges the only fully wind & waterproof solution that was posted.
