Strong backbone network for today is mostly for large file transfer as my 100Mbps internet speed is hardly stress. There are not many content providers in S'pore that offer triple plays.
Unless you are moving data constantly/streaming uncompressed HD video, all you need is Cat 6 run to the rooms and terminated at a patch panel that then goes to a gigabit switch. As it's been pointed out, 1 gbps from the demarc to an end device is unlikely with residential gear.
With FTTH coming this year, i hope the 100Mbps speed would be stretch a bit. Current HD content uses compress method to deliver to our home but if FTTH offer 1Gbps and they open shop here, we are in for a treat.:biggrin:
So, they are going to start offering uncompressed HD? Interesting. Have a link for that?
My current Dlink DNS-323 does not support external HDD and its only 100Mbps. Will need to upgrade it to newer model which comes with 1Gbps so that i don't have to wait that long for large file transfer.
If you're buying a new NAS, why not buy one that supports eSATA hd's and/or USB 2.0 (or 3.0 if you wait a year or so)? You're spending the $ on a new NAS, might as well get one that you can use eSATA with then just do it all directly to the NAS.
Yes, you are right. My Marantz AV8003, bluray and HDTV do not have 1Gbps. But i am sure in 1-2 years time, AV receiver will start rolling 1Gbps port to stream HD contents from NAS. I know that they don't matter so much now.
Okay, now you're talking about streaming HD again. Unless you're storing this HD content uncompressed, you can do multiple streams on a 100 mbit network. Based on the NAS you have, you can't have more then 4 TB on it which uncompressed HD videos would eat up very quickly. I don't see HT makers putting in gigabit ports in their mainstream devices for a few years still, and that will only be done because it will reach a price parity with 10/100 gear. It won't be because they are reaching the limits of fast ethernet (100 mbps).
But the device number that needed a UTP point counts today. For me, when i am set to do something for long term, i will do the best that i could afford today (not much though) even though some deem it as silly.
All my PCs has 1Gbps NIC.
If you can't afford much, why are you trying to make some expensive elaborate network that is 1 gbit on the backbone? You have 3 seperate things going on. First is you are trying to create a network that supports IPTV, which here in the states isn't available (I don't know about Singapore or your provider though). If they do in fact use an IP network, then they will wire it most likely just as cable tv providers do currently. Second, you want this to be a "one time thing" or last 15 years. That makes sense, but to do that just use Cat 6 cables to a patch panel and use a gigabit switch to connect it all. Third, you have your actual network, which if you do lots of transfers is only internal to your network. For that you *only* need a gigabit network, and that can be done with Cat 6 and a gigabit switch (although a 48 port gigabit switch will be a few hundred USD).
You really are making this more complicated than it needs to be
